D15B swap.
Old Sep 30, 2008 | 06:38 PM
Lateralus_EG's Avatar
Default D15B swap.
Hey im considering getting a d15b vtec for my 93 si hatch. Im a little confused on a few things. I see a lot of posts about the O2 sensor wiring and getting the ecu chipped for a p08. Im just wondering what things i need to do to swap in this motor i tried searching a few different forums and those are the only 2 things im still confused about. Thanks in advance.
Old Sep 30, 2008 | 06:45 PM
Kendall's Avatar
The D15B came stock with a 1 wire O2 sensor where almost all other Honda's came with a 4 wire O2 (exceptions being 92-95 CX and VX hatchbacks).
Likewise the P08 ECU only requires a 1 wire O2 sensor, but you can use a 4 wire instead of a 1 wire and not have issues.
That said if you are running your stock P28, then use the 4 wire O2 sensor already on your car. If you are using a JDM P08, you can use either a 1 wire or a 4 wire O2 sensor.
Before you do anything, is there something wrong with the stock D16Z6 that would necessitate this swap? If not, then why bother?
Old Sep 30, 2008 | 07:19 PM
Default Re: (Kendall)
It was neglected for the 200k before i got it. The rings are shot and its burning a lot of oil. I plan on putting the d15b in and rebuilding my z6 to handle some horsepower. im not a big fan of the b series swaps.
Old Sep 30, 2008 | 08:18 PM
wite2nr's Avatar
is there a write up on the d15b swap? i just purchased a 93 si del sol and have 200k+ on the z6 and am interested in doing this myself.
Old Sep 30, 2008 | 10:03 PM
TeamRPM_ZC's Avatar
Default Re: (Lateralus_EG)
i got the D16A, is there any difference between the D15b and the D16a
powersk8er92
Sep 15, 2009 11:41 AM
SPOON_BeIgHtEeNsEe
Mar 3, 2008 03:26 AM
pinecone
Apr 1, 2006 05:51 PM
dropd4door
10
Dec 27, 2004 06:07 PM
chad
Aug 25, 2004 01:58 PM
