Heat shield problem
Old Jul 27, 2002 | 03:38 AM
127.0.0.1's Avatar
Default Heat shield problem
My damn heat shields are rattaling away on my ride and I want to take them off... anyone have any suggestions on the easiest way?
Old Jul 27, 2002 | 03:49 AM
DSC's Avatar
DSC
Default Re: Heat shield problem (95'd15b7)
Take off the two screws before taking off the heat shield
Old Jul 27, 2002 | 05:55 AM
127.0.0.1's Avatar
Default Re: Heat shield problem (DSC)
damn... I meant like any problems you encontered.... thanx for lowering my IQ
Old Jul 27, 2002 | 06:50 AM
deepnite's Avatar
my problem was getting them on..but u could just get hacksaw and solve ur problem
Old Jul 27, 2002 | 06:53 AM
M-EJ1's Avatar
you mean the cat heat shield? Jack up your car, support with jackstands... crawl under, find two 10mm bolts holding the heat shield to the body of the car... remove those two, and pull it out. No sweat. I'm pretty sure you can even do it without removing the cat, as it's only two bolts, and neither of them is up in the tunnel behind the cat.
Old Jul 27, 2002 | 07:01 AM
deepnite's Avatar
Default Re: Heat shield problem (matt-eg)
i thought it was the shields to the cai
Old Jul 28, 2002 | 10:07 AM
127.0.0.1's Avatar
Default Re: Heat shield problem (deepnite)
man its amazing what 15 bucks can get you at the local monroe...
those guys got out the cutting torch and cut like 20lbs of stell of the bottom of my ride!!!
Old Jul 28, 2002 | 10:11 AM
drvfast's Avatar
just don't drive over high grass if u remove the heatsheild from the cat.
JonathanRuiz
Nov 29, 2004 04:32 PM
BrokeAssAcura
Apr 30, 2003 12:06 PM
stickman12
Jan 22, 2003 11:23 AM
ekimmel
Apr 16, 2002 10:14 AM
Woody_geeser
Jun 28, 2001 11:37 AM
