help with bleeding clutch
Old Sep 30, 2008 | 04:32 PM
smashin94eg's Avatar
Default help with bleeding clutch
hi i am having a stupid problem and i cant figure it out. so i am in the process of puttin my car back together 94 civic coupe, and i am trying to bleed the clutch, i have a one person vaccum bleeder that dosent work at all, and i have had another person inside the car, tried to gravity drain, i have even tried to bleed it at every fitting still nothing, and i have bleed the master like 4 or 5 times to make sure there was no air in there. so any help would be great thanx.
Old Sep 30, 2008 | 05:51 PM
sorrule's Avatar
so what exactly is your problem? Is your clutch pedal feel too soft or the clutch isn't engaging?
Old Sep 30, 2008 | 07:07 PM
durfeec's Avatar
Default Re: (sorrule)
i just did this to my 94 civic like a month ago.
i sat in the car and pumped the pedal like 5 times and then my dad loosened the bleeder on the front of the tranny. it took awhile like 3 full resiviors till the pedal was the way it was.
i guess im not sure what you problem is though.
Old Sep 30, 2008 | 07:15 PM
Juan_Mitosis's Avatar
Recently i had to bleed my clutch because all the fluid leaked out. I had to pump the pedal damn near 150 times before it actually started MOVING the clutch. If your system was near drying out or something, just pump it like 100 times, not 10, 100, and THEN have someone open and close the little screw on the slave cylinder. The bleed screw is it called?
Good luck!
Old Sep 30, 2008 | 07:22 PM
SilverAWD's Avatar
Give us details of what the problem is.
Old Sep 30, 2008 | 08:15 PM
wite2nr's Avatar
interesting, i have changed a clutch and not even had to bleed it
Old Sep 30, 2008 | 08:32 PM
sorrule's Avatar
well if it was completely dry, you may have to bleed the clutch master cylinder itself like you would a brake master cylinder, and then bleed out the clutch line and slave cylinder.
Old Oct 1, 2008 | 10:06 AM
my problem is the fluid isnt going through the line at all, kinda weird. i have bleed the master more than once and the slave cylinder. the whole system was dry. is it possible that their is air getting past the seal on the slave cylinder?
Old Oct 1, 2008 | 10:10 AM
Default Re: (wite2nr)
when u pump it and open the bleeder then close it and pull the pedal off the floor it seems like it dosent even pull any fluid down the resivior. maybe i just need to be persistant with it but im unsure
Old Oct 1, 2008 | 10:11 AM
Default Re: (durfeec)
the pedal drops to the floor cause there is air in the system, no hydralic pressure
Old Oct 1, 2008 | 11:09 AM
sorrule's Avatar
you may have a bad master cylinder
Old Oct 27, 2008 | 08:44 AM
TravisCadello's Avatar
so pump it 100 times and then hold it and open the line? and repeat or what?
CraiGlOl
Jul 9, 2009 07:52 AM
integragsssr
Feb 6, 2009 08:54 PM
molezy7
Sep 4, 2008 05:57 PM
88crxdxfastwhip
Jun 5, 2007 01:05 PM
91DA9
Feb 5, 2002 07:57 AM
