engine mounts
Old Sep 30, 2008 | 07:18 AM
949's Avatar
949
Default engine mounts
im installing aftermarket innovative engine mounts and have questions on the drivers side mounts. the mount has two bolts there, oem. i can take one out cause its a bolt and nut. the other one is a threaded stud which can be unscrewed out leaving a threaded hole.
one hole is threaded and i wanted to use that threaded hole along with the non threaded hole.
the two bolts for the mount, what are you guys using to make it look clean?
i wanted to use arp bolts but the shop said they dont make the correct threaded bolt on the arp's to work. arp look very nice and would have complimented that area.
what are you guys using for bolts?
any pics would help.
decode33
Honda CR-V & Element
Jun 1, 2011 06:51 AM
spens 91 Ef
Feb 8, 2009 01:50 PM
gsxr1k05
Sep 24, 2006 07:52 PM
DA-MAX
Nov 23, 2003 05:15 PM
