Head Change!!!
Old Sep 29, 2008 | 07:23 PM
civicdude16's Avatar
Default Head Change!!!
Ok I have a 90 civic hatch... it has the gay dpfi manifold with a d16w7 block non vetc head... I want to do a head change... I want a D16y8 VTEC head on it... A buddy told me i could put it on my block but it would take alot of work to do.... I need some help.... and i dont really know what parts i need to do the swap.. If someone could make me a parts list that'd be great... but im new to this swap stuff... I dont really know what parts that i need, im not a mechanic im in auto body... thats what i do, but any help would be great..
Old Sep 29, 2008 | 08:28 PM
sleepingciv's Avatar
Default Re: Head Change!!! (civicdude16)
how ya running a 2003-2005 engine in your car?
Old Sep 30, 2008 | 07:15 PM
Default Re: Head Change!!! (sleepingciv)
i may have put down the wrong numbers.... i dont have my car with me right now, its at the shop... but ill check tomorrow and get back at ya... it might be a d16z6... but ill tell ya tomorrow..
Old Sep 30, 2008 | 08:50 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">how ya running a 2003-2005 engine in your car?</TD></TR></TABLE>
I appreciate that you are trying to be helpful but you reply to absolutly EVERY thread and arn't usually full of useful and/or correct info.
The op meant d16y7 and that is a 96-00 motor. PLEASE know what you're talking about if you want to try to help.
I have had to facepalm at too many of your replies recently and I just couldn't take it anymore.
Edit: Sorry OP. What you want to do is called a "mini-me." It is well documented and a quick search will find you all sorts of threads pertaining to the topic.
Modified by 89s1 at 9:58 PM 9/30/2008
Old Oct 1, 2008 | 10:50 AM
efjones9's Avatar
Default Re: Head Change!!! (89s1)
lol!!!???? ^^^^
search mini me swap and it will give u your options and everything u need to know about it
Old Oct 1, 2008 | 01:33 PM
dacrxguy's Avatar
http://crx.honda-perf.org/arti....html
Old Oct 1, 2008 | 01:53 PM
Default Re: Head Change!!! (dacrxguy)
* Vtec-E
* Found in:
o 2005-2007 Honda Civic Vti-L/ Vti (Asia)
+ Displacement:1590 cm3
+ Compression : 10.9:1
+ Power : 115hp 5600 rpm & 152Nm 4300rpm
+ Valvetrain : SOHC
+ Redline 6100 rpm
+ Limit 6200 rpm
+ Fuel Control : OBD-1 MPFI
+ ECU Code: PM12
* Also found in 2001-2005 Honda Civic (Europe)
o Same as above, except:
o Power: 110hp (81kW) @ 5600 rpm & 152 Nm @ 4300 rpm
o Redline 6100 rpm
o Limit 6200 rpm
So the OP said he was running the d16w7 block , so I asked how.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">
[/i]</TD></TR></TABLE>
What other info have i givin that was wrong please tell me.I answer alot of stuff because other people dont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efjones9 &raquo;</TD></TR><TR><TD CLASS="quote">
lol!!!???? ^^^^
search mini me swap and it will give u your options and everything u need to know about it</TD></TR></TABLE>
learn how to read codes before ya laugh at someone else
Old Oct 2, 2008 | 11:42 AM
Okay its a D16z6... but with a d15 head... I just want a d16y8 head and a list of pats i need to get it running smoothly..
Old Oct 2, 2008 | 11:56 AM
sgallagher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdude16 &raquo;</TD></TR><TR><TD CLASS="quote">Okay its a D16z6... but with a d15 head... I just want a d16y8 head and a list of pats i need to get it running smoothly..</TD></TR></TABLE>
Again search mini-me. The info is all there.
Old Oct 2, 2008 | 11:57 AM
Are ya wanting to run obd1? and mpfi swap?
Old Oct 9, 2008 | 10:32 AM
Yeah thats what i want to run... and i just bought an intake manifold and port and polished it to put on...
Old Oct 9, 2008 | 12:46 PM
CRX Toad's Avatar
I don't understand what you really want but I am sure it is covered here
https://honda-tech.com/zerothread/1508680
Old Oct 9, 2008 | 05:16 PM
Default Re: Head Change!!! (CRX Toad)
I mainly want a single just a single cam VTEC.. and I just dont want to go through an engine swap i just want to change heads..
Old Oct 10, 2008 | 07:24 AM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdude16 &raquo;</TD></TR><TR><TD CLASS="quote">I mainly want a single just a single cam VTEC.. and I just dont want to go through an engine swap i just want to change heads..</TD></TR></TABLE>
Search for info on a "mini-me" swap. sohc vtec head on a sohc non-vtec block. I already said it in my post way the hell up there ^^ pay attention.
all around. it's E-beer friday afterall.
I miss kills
rhymeshark916
Northern California
12
Jan 11, 2012 01:54 PM
deeweezy187
Sep 12, 2006 09:43 AM
crxsleeper210
Mar 27, 2006 08:36 AM
eg4usdm
13
Mar 11, 2005 04:30 PM
nucivowner
Feb 14, 2005 02:14 PM
