can someone tell me what this plug is?
I wanted to see if anyone can check their car and take a pic or at least tell me what this plug goes to. Its a yellow plug and has a thick black wire and athick blue/white wire, its in the front passenger side of the engine bay. Thanks a lot if you could help, it might be for ABS im not sure
its for a 93 LS
Modified by white94 at 5:28 PM 9/29/2008
its for a 93 LS
The alt. is in the rear driver side of the engine bay...so probably not. I know on DA's the ABS (if you have an equipped model) is near there. I do not have a DA to check however. Good luck!
Nah its not the dist. And all ABS are usually pink connectors so I dont think its that. The car runs perfectly fine so its not something major, possible to the fan or something along those lines....still looking
