camshafts
Old Jul 26, 2002 | 10:10 PM
DKay04's Avatar
Default camshafts
ive already removed my camshafts and i didnt know i was sapposed to set my 1 piston to TDC how do i go about setting it and also now that ive got the camshafts out of the car how do i go about removing the camgears from the camshaft??
Old Jul 26, 2002 | 11:46 PM
IN VTEC's Avatar
Default Re: camshafts (DKay04)
Electric impact wrench (14mm socket) for the camgears.
Use the hook tool from your car jack tools and insert it into the #1 cylinder. Crank the engine CCW until cylinder #1 is at TDC and the crank pulley white mark indicates TDC.
Old Jul 27, 2002 | 05:26 AM
Chiovnidca's Avatar
Default Re: camshafts (IN VTEC)
What are you doing with the jack tools?
Old Jul 27, 2002 | 06:12 AM
Mikey3000's Avatar
lol you should of taken the cam gear bolts off with the belt still on. they're gonna be a bitch to take of now. actually, i guess you could put the cam gear in a vice and bust them loose. to get #1 at tdc turn the crank til you line up the mark on the flywheel with the pointer on the block. then put the cams in.
Old Jul 27, 2002 | 07:00 AM
earl's Avatar
Default Re: camshafts (Salvatore Leone)
Yeah, you just have to set the crank on the timing mark for #1 (same as #4, it doesn't matter). No need to worry about seeing if piston is up, it will be.
Wrap some rags around those cams and have a friend hold them. Hit the cam bolt with an impact and it will come out.
BE SURE to reinstall the cams pointed in the #1 position. It's easy to be off a tooth the first time you try this, so check your work.
Old Jul 27, 2002 | 11:47 AM
IN VTEC's Avatar
Default Re: camshafts (Chiovnidca)
Improvising. If you're paranoid about a screwdriver of whatever falling in, the hook on the tool will keep it from falling in. Try it....you might even like it.
Old Jul 27, 2002 | 12:00 PM
Chiovnidca's Avatar
Just go by the white mark on the crank pulley. There isn't any need to put anything in the cylinder.
Old Jul 27, 2002 | 12:06 PM
IlikeTODA's Avatar
If he has the cams out I'm assuming he has taken the timing belt off along with the crank pulley. There is also an arrow on the oil pump that you can use, or put the key slot on the crank shaft straight up, or pull the #1 or #4 plug and put something like they said or a stick, then when its at its highest point you are good to go.
Thanks, J
Old Jul 27, 2002 | 01:44 PM
Chiovnidca's Avatar
Default Re: camshafts (IlikeTODA)
Ahh, I see. It's just to get it close.
zsnarl
Jan 27, 2010 07:14 PM
jyracer
Jan 29, 2009 09:29 PM
Perogi
Dec 22, 2005 07:26 PM
MaxSterling
Jul 9, 2003 06:57 PM
red00gsr
May 30, 2003 10:05 PM
