JDM FD Review
Old Jul 26, 2002 | 10:03 PM
Big Teggie's Avatar
Default JDM FD Review
Nothing to do tonight, so I figured I would post a review.
Recently I installed a JDM 4.7 FD in my GSR. I already had an ITR tranny which I installed the FD into. The countershaft was busted up in the trans so I needed a new one. I opted for the JDM FD becuase I always wanted to try it out, and now was the best time.
I did alot of research about the JDM FD and the ATS FD. I came to the conclusion that my car is a daily driver and the only racing I really do is drag, so I would go with the JDM FD. I figured it would be good for me if I want to get into road racing or autocross, which I plan to soon. I was under the impression that the ATS was for a car that does more road racing. I also read alot about the option of installing a GSR 5th, and most people said it was a waste. Seemed like people really into racing were saying this.
I have never driven in a car with either of the final drives until I put mine in. So this was my first experience. All I can really say is "WOW". I was driving around with my original GSR trans where the gearing felt liek ***. Goin from a GSR trans to an ITR with a FD is awsome. As soon as I pulled out of my driveway and accelerated, I could feel the difference. Every gear picks up very fast and shoots to redline. In first you need to pay close attention as to when to shift. Then I just plow thru the gears. I installed a GSR 5th gear, and I honeslty think it is worth it for the highway in the 80mph range. My exhuast is kind aloud and the higher I rev, the louder it gets. So now 5th is the same as it would be as with a stock ITR trans. I also have a CM Flywheel and CM Stage 3 Clutch in my car. The flywheel works very nicely with the final drive.
I did all the work on the transmission myself. It really isnt the complicated, once you open it up and go step by step with the Helms. I would also like to thank everyone who answered my questions about the install and for giving very helpfull tips.
After driving my car now, I would really like to drive in something with the ATS to have something to compare too. With what my car feels like now, I can only imagine what the ATS feels like.
Old Jul 26, 2002 | 10:28 PM
01PYITR's Avatar
Default Re: JDM FD Review (Big Teggie)
Good Job!
Old Jul 27, 2002 | 02:27 AM
rainmanEK's Avatar
big strong guy
Default Re: JDM FD Review (01PYITR)
awsome dude, cant wait to install mine!!! eric
Old Jul 27, 2002 | 10:10 PM
B2FiNiTY's Avatar
I want a JDM fd! Thanks for the review
Old Jul 27, 2002 | 11:54 PM
Keyed ITR's Avatar
Default Re: JDM FD Review (B2FiNiTY)
I want to get a FD also. I suppose FDs and HIDs are in the same boat.
You just can't lose with either!
Old Jul 28, 2002 | 12:22 AM
CPR's Avatar
CPR
Default Re: JDM FD Review (Keyed ITR)
You lose money in both that's for sure.
Too bad you couldn't do stock ITR tranny to ITR Trany w/JDM FD comparison. Some people say they don't notice a difference and others say that you can definitely feel something.
[Modified by CPR, 4:23 AM 7/28/2002]
Old Jul 28, 2002 | 07:02 AM
Big Teggie's Avatar
Default Re: JDM FD Review (CPR)
I did have the ITR tranny on my car for about 2000 miles. The when the ITR tranny broke i put my old GSR trans back on to just get around with. Now I have the ITR back in again. I can feel a big bifference in the ITR trans with the new FD.
It is very noticeable.
Old Jul 28, 2002 | 10:14 AM
CPR's Avatar
CPR
Ah, I see. That's good to hear because I was starting to doubt the butt dyno effects of the JDM FD.
Old Jul 28, 2002 | 03:30 PM
Big Teggie's Avatar
You can definatly feel the difference. No way you can miss it.
Old Jul 28, 2002 | 03:36 PM
GokuSSJ4's Avatar
thanks for the Review , how much did you pay for your jdm FD ?
also im defenetly going with the gsr 5th gear , IMO is way worth it if you drive a lot on the freeway ....
Old Jul 28, 2002 | 03:40 PM
Big Teggie's Avatar
Default Re: JDM FD Review (Spoon1)
I bought is for either $400 or $425 shipped. I forget which. You can usually find shops selling them for around $475.
Old Jul 28, 2002 | 10:40 PM
GokuSSJ4's Avatar
thanks ...
Old Jul 28, 2002 | 10:41 PM
B2FiNiTY's Avatar
http://www.jdmspecperf.com has some coming I believe for a good price. Hopefully they aren't all presold.
Old Jul 29, 2002 | 09:18 AM
AK94GSR's Avatar
Big Teggie: Have you ever done any tranny work before this or was this your first time???
Old Jul 29, 2002 | 10:01 AM
Big Teggie's Avatar
Default Re: JDM FD Review (AK94GSR)
My first time. I just took my time, as not to rush anything, and forget some small detail.
mingchi96
Guest
Posts: n/a
in yr opinion.. is there a big difference between a stock gsr tranny and a ITR tranny (both stock 4.40 final drive). Im just curious because I just swapped out ITR gears 1-4 into my gsr tranny and an LS 5th gear. Going from stock gsr gears to ITR, you think there will be a noticeble amount of difference? Thanks
Old Jul 29, 2002 | 10:09 AM
ragejed's Avatar
Default Re: JDM FD Review (mingchi96)
so what is a Final Drive? I thought it was 5th gear, guess Im wrong
TypeC's Avatar
What are your shift points at 8K in each gear now?
That 1st to 2nd shift is what killed me in my GSR.
Old Jul 29, 2002 | 10:12 AM
Big Teggie's Avatar
I noticed a big difference when I just swithed out the ITR tranny for the GSR. The gearing just keeps you up higher in the powerband. You will notice the difference. Why did you get an LS 5th. The GSR 5th would have been fine.
Old Jul 29, 2002 | 10:28 AM
Big Teggie's Avatar
Default Re: JDM FD Review (TypeC)
Shifting an indicated 8k on the tach.
1--->2=6200
2--->3=6300
3--->4=6300
4--->5=5800
Those are not that exact, just went for a quick drive. They are with pretty quick shifts and I get a decent amount of wheelspin goin from 1>2 and 2>3. Those rpm are probably off bt around 75-100 rpm, I didnt have enough time to look at my vafc.
Old Jul 29, 2002 | 11:47 AM
TypeC's Avatar
1--->2=6200
2--->3=6300
3--->4=6300
4--->5=5800
Tight
Before, I'd have to speed shift and spin the wheels to keep the secondary runners open on the 1-2 shift. I bet you gained a couple tenths from that swap alone.
Old Jul 29, 2002 | 11:50 AM
B2FiNiTY's Avatar
Default Re: JDM FD Review (ragejed)
The final drive is a "gear" that determines all your gear ratios.
Old Aug 2, 2002 | 01:49 AM
ragejed's Avatar
yummmy...me want, heh
Old Aug 2, 2002 | 02:00 AM
itr1244's Avatar
so installing by your self isnt that hard??
damn man~ are you a mechenic or something?
how long did it take you ?
Old Aug 2, 2002 | 02:06 AM
4-1-1's Avatar
Interesting
