ecu diagram needed for obd1 p30
Old Sep 29, 2008 | 12:15 PM
slammedz6ef's Avatar
Default ecu diagram needed for obd1 p30
ive searched all over and can not find anything
i have all my wires from the vtec solenoid hooked up except the oil pressure and i need to know what pin it goes to.
thanks for your help guys
Old Sep 29, 2008 | 01:34 PM
Default Re: ecu diagram needed for obd1 p30 (slammedz6ef)
i have it hooked up but its not working and it has a cel on but idk on to check it on the obd1 p30
Old Sep 29, 2008 | 01:52 PM
gringo7718's Avatar
How to check codes:
http://www.c-speedracing.com/faq/06.php
CEL Codes:
http://www.c-speedracing.com/faq/05.php
OBD1 ECU Pinout:
http://www.ff-squad.com/technet/wiring.obd1.htm
More Info: (If you dont have blue connector, you can do it manually - you have to ground Pin#D4 to ground to check CEL codes)
http://images.google.com/imgre...a%3DN
Modified by gringo7718 at 11:05 PM 9/29/2008
max_fixed
37
Mar 29, 2013 06:09 AM
honda305
Jan 7, 2009 08:37 PM
chimmike
Engine Management and Tuning
May 27, 2008 03:58 PM
sgi
Feb 7, 2003 03:24 PM
KevronsEG
Jan 21, 2003 02:22 PM
