Check eng. with KOEO and gas floored?
Car is a b18c - starts for a few seconds and dies, with the key on and engine off and the gas floored the check engine light will stay on, as soon as i take the gas off the engine light goes away. i tried switching the green/yellow tps wires but that didnt work.
anyone else had this problem? i just manually converted the car to OBD1
timing is correct
dizzy wiring is correct (did a pinout from the ecu to the dizzy)
im thinking this has to do with reference voltage since it is dependent on throttle angle.
please save your comments if you are going to bash me for doing it the hard way.
timing is correct
trouts2
Nov 23, 2016 05:54 PM
CW_97_ITR
Nov 19, 2001 08:50 PM
