Transmission & Drivetrain Gearboxes, Differentials, Clutches
Will 97 Civic HX axles fit Si cable trans
Old Sep 29, 2008 | 08:55 AM
alupso's Avatar
Default Will 97 Civic HX axles fit Si cable trans
Posted this in the CRX/Civic forum but wasn't sure of the answer.
Need some axles quick and someone has some axles from a 97 Civic HX. Will they fit a cable Si trans with Si hubs?
Here's what I found from the NAPA website:
Si axles
Item#: NMD956108
Product Features:Compressed Measurements Used To Determine Length.
Compressed Length:35 9/16"
Spline Count of Inner Joint:25
Spline Count of Outer Joint:26
HX axles
Item#: NMD956167
They have different part numbers but the same measurements
Si axles:
A-1 CARDONE Part # 604002 {Reman CV Half-Shaft Assembly / Overall Length=23.6875" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Right
A-1 CARDONE Part # 604003 {Reman CV Half-Shaft Assembly / Overall Length=35 9/16" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Left
HX Axles:
A-1 CARDONE Part # 604060 {Reman CV Half-Shaft Assembly / Overall Length=35 9/16" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Left; w/ABS
A-1 CARDONE Part # 604064 {Reman CV Half-Shaft Assembly / Overall Length=24.5" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Right; w/ABS
Old Sep 30, 2008 | 08:18 AM
Aquafina's Avatar
Default Re: Will 97 Civic HX axles fit Si cable trans (alupso)
No.
Old Sep 30, 2008 | 08:23 AM
alupso's Avatar
Default Re: Will 97 Civic HX axles fit Si cable trans (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">No.</TD></TR></TABLE>
Ok, how come, I trust your answer but just curious as to why they wouldn't.
Old Sep 30, 2008 | 01:36 PM
Mista Bone's Avatar
D Tranny Guru
wrong length
Old Sep 30, 2008 | 01:39 PM
alupso's Avatar
Damn your right, how did I miss that one
Thanks
h22acd5
Mar 23, 2021 01:50 PM
cityofcaterpillars
Apr 16, 2016 03:24 PM
alupso
Sep 28, 2008 01:58 PM
bluez6
Aug 27, 2006 12:49 PM
NegativeXero
Aug 27, 2006 12:52 AM
