Question on wiring of the Field SFC
Old Sep 28, 2008 | 11:04 PM
BB1 H22A LUDE's Avatar
Default Question on wiring of the Field SFC
Hey
I have search all over the net to try to sort out the wiring for this slightly dated vtec controller !! The unit that I got is second hand and was simply cut out of a honda. I have found the online PDF for it but there is 4 wire's for which I still have No function. If any one out there has ever installed one of these could you please bail me out, Thanks.
I have used several sources to obtain what I have so far which is:
(Note: these are the coloured wires that originate from the Field SFC vtec controller's harness)
Black- Ground
White&green- VTM-ECU side
Orange- Map-ECU side
Brown- Map- sensor side
Yellow- Vtec- ECU side
Dark Blue- Vtec sensor
Green- Taps into ICM on the ECU harness, RPM signal
Red - Taps into IGP1 on the ECU harness, Ignition Power
Purple- VSS- ECU side
Light Blue- VSS- sensor side
I still need to find the function of:
Pink-
White&red-
Gray-
White-
If you know the function of any of them it would be great
Thanks for your time
Barry116
14
Feb 1, 2012 01:56 PM
leftcoast
Aug 9, 2007 08:51 PM
WickedWerx
Oct 24, 2004 06:15 PM
teg2000
Nov 6, 2003 03:29 PM
Sir_Phobos
Jan 12, 2003 04:49 PM
