Fog Lights, Headunit, and Dash light NOT WOrking!?
my fogs and dash lights and headunit aren't working. The turn signals work but are not on when the lights are on. Im assuming a fuse and not a bad broken headunit or blown bulbs. Any input on what the the issue might be? also are there any sick jdm fogs for tegs? and what springs are ride best and are have the most aggressive low look? any feedback would be awesome thanks
-eric
-eric
Check your fuses. Are your turn signal markers and tail lights not working as well?
This has happened to me a couple times from a blown fuse. The tail lights, turn signal marker, cluster, climate control, and if you ran the fog lights through your running lights, are all run from one fuse in the fuse box located in the car. Check all the fuses to make sure they are good.
As for the head unit, I've had that problem once before as well. There was a blown fuse in the fuse box under the hood. Replaced that, and the problem was solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcforgod »</TD></TR><TR><TD CLASS="quote">my turn signals and tail lights are working, I'm thinking a wiring problem. </TD></TR></TABLE>
I take it the fuses are fine then? Has the wiring ever been tampered with? Run through the wiring to make sure. That's probably where your problem lies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95silverteg »</TD></TR><TR><TD CLASS="quote">my fogs and dash lights and headunit aren't working. The turn signals work but are not on when the lights are on. Im assuming a fuse and not a bad broken headunit or blown bulbs. Any input on what the the issue might be? also are there any sick jdm fogs for tegs? and what springs are ride best and are have the most aggressive low look? any feedback would be awesome thanks
-eric</TD></TR></TABLE>
OP definitely check that fuse that sounds like the cause of your problem. My turn signals did work, but they did not work as running lights when the rest of the lights were turned on as well. Do your tail lights work? When my fuse blew only the brake lights would come on.
Gatschet
23
Aug 25, 2021 10:35 AM
Soulman41
Sep 25, 2014 10:00 AM
88aeFC3S
Jan 3, 2010 11:38 AM
