gsr idle problem
Old Sep 28, 2008 | 01:44 AM
quicksilver1689's Avatar
i ♥ snails
Default gsr idle problem
Hey i got some questions for you all motor guys, got this car its my roomates, 99 EK hatch with a gsr swap. itr pistons, cams, intake and exhaust mani. Its having this rough idle problem. It bounches between 1300-1500 and idles it has vtec killer cams. Thought it was the tps, checked voltage at the ecu, .470 at closed throttle, 4.5xx at wot, sweeps fine no flat spots, replaced fpr for ***** and giggles, no change. weird thing is the idle is the same with or witout the vaccum line on the fpr connected. Runs complete fine, accept for its idle issues, smells extremely rich tons of raw fuel, all injectors are pulsing correct. Starting to think something wrong with the map sensor, it has a 2.5 pr 2.7xvdc signal at idle, not sure of the spec. hooked up a vaccum guage during its idle issues, it bounced between 10-14" of vacuum
Cant figure it out for the life of me, compression teste showed 250-255 psi compression. Any useful insight would be appriciated. thanks
Old Sep 28, 2008 | 05:47 AM
kyden's Avatar
Default Re: gsr idle problem (quicksilver1689)
do you have the map and tps plugs mixed up?
Old Sep 28, 2008 | 12:11 PM
i ♥ snails
nope there both correct.
Old Sep 28, 2008 | 01:12 PM
ATXhatch's Avatar
how long since you changed your spark plug wires?
they can cause a rough idle, and if it smells rich it could be because youre getting a bad spark
Old Sep 28, 2008 | 09:20 PM
ATXhatch's Avatar
also, if it has vtec killer cams, it really needs a tune.
adding cams with a big profile makes the car idle poorly. thats why some cams say "keeps stock idle characteristics" and others dont
Old Sep 29, 2008 | 01:13 PM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">it has vtec killer cams. </TD></TR></TABLE>
that's probably normal for that setup. lots of overlap is for high rpm, not idle.
B17DA-SON
Feb 5, 2010 09:23 PM
welfarepc
Sep 13, 2007 05:15 PM
coronadrinker
Oct 9, 2006 05:11 AM
mikeunreal2
Mar 29, 2006 09:27 PM
