opinions on my ls/vtec setup please
ok so my ls/vtec build is almost complete, i would like some opinions on my setup
b18a1 block, 81mm bore
pr3 pistons, ls rods, arp rod bolts, ls crank
gsr water pump and oil pump
golden eagle conversion kit w/ headgasket
b16a2 head
buddy club spec 3+ cams
buddy club dual valve springs, b16 retainers
buddy club adjustable cam gears
skunk2 pro series intake manifold
b18a1 throttle body
b18a1 fuel rail and injectors
4-1 type r stainless header, 2.5"
apexi afc neo (air/fuel, vtec controller)
this is my first build and i wanna do it right the first time, does this set up look ok?
thanks
Modified by seldon at 8:00 PM 9/27/2008
b16a2 head
b18a1 throttle body
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seldon »</TD></TR><TR><TD CLASS="quote">ok so my ls/vtec build is almost complete, i would like some opinions on my setup
b18a1 block, 81mm bore Have the block checked, it may require a bore and hone
b16a2 head
buddy club dual valve springs, I'm not sure if these retainers will work with those valve springs b16 retainers
b18a1 throttle body get a 65mm Professional Products
apexi afc neo (air/fuel, vtec controller) get a chipped P28 it will be cheaper and you can use Crome/Uberdata or Hondata/Neptune
thanks
Comments in bold
GL
b16a2 head
thanks
Comments in bold
GL
lol, like anyone else i want the most i can out of it, i don't set goals for hp, i see to many people on here setting hp goals then gettin upset when they can't hit them
i'm just lookin for a good solid build, it's a daily driver, like to have a bit of fun auto crossing on the weekends thats why i aimed for the low/ mid range hp
awdriscol4
Dec 30, 2004 11:16 PM
