tranny
Old Sep 27, 2008 | 04:53 PM
85crx509's Avatar
Default tranny
how do i figure out what kind of tranny i have in my car .
i ask cause it doesnt have any sticker on it .
the motor is a b18a1 from a 90 -93 teggy so ive been told on this forum.
would it be stock tranny cause the housing lines up perfectly with the motor?
help. cause im looking to purchase a new clutch, i dont know what kind yet.
Old Sep 27, 2008 | 04:56 PM
gearhead16's Avatar
Default Re: tranny (85crx509)
whats your rpms at in 5th gear around 50 to 60 mph
Old Sep 27, 2008 | 05:00 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: tranny (gearhead16)
Look at your tranny sticker as well.
Old Sep 27, 2008 | 05:03 PM
sleepingciv's Avatar
Default Re: tranny (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">Look at your tranny sticker as well.</TD></TR></TABLE>LOl he said no sticker
Can you get the motor stamp on it? To be sure.Its prob the stock trans on it.
Old Sep 27, 2008 | 05:07 PM
sgallagher's Avatar
Default Re: tranny (sleepingciv)
Get the clutch for the engine. If its a cable clutch still you only have a couple of choices of tranny. Chances are whoever installed the engine didn't swap the tranny and if they did the flywheel is still the same.
Old Sep 27, 2008 | 05:09 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">LOl he said no sticker
Can you get the motor stamp on it? To be sure.Its prob the stock trans on it.</TD></TR></TABLE> Touche &gt;_&gt;
D16SiHatch's Avatar
even if it is stock, which it most likely is. he needs to know if its a 90-91 engine/trans or a 92-93. input shaft on the tranny for 92-93's is 1/16" an inch larger than the 90-91 trannys. i would say that if he has the resistor box still, that its probably the 90-91 tranny, however theres a reasonable possibility someone elected to use the obd0 injectors on the 92-93 engine when it was swapped, and then retained the resistor box. that being said, i'm not really sure how to figure out which one it is
Old Sep 27, 2008 | 05:14 PM
85crx509's Avatar
resistor box?
where is it?
Old Sep 27, 2008 | 05:18 PM
85crx509's Avatar
rpms?
hhhmmmm let me think.. high i assume like 3k-4k? i havent drove the car in a while.
also y do hondas rev so high when freeway cruising? short gears?
D16SiHatch's Avatar
Default Re: (85crx509)
driver side shock tower area, nearest the firewall. If its there it doesnt really prove anything cause the engine could be obd0 or obd1. if it is not there, then it is very likely a 92-93 engine.
Old Sep 27, 2008 | 05:21 PM
85crx509's Avatar
Default Re: tranny (sgallagher)
any help?
Old Sep 27, 2008 | 05:22 PM
D16SiHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85crx509 &raquo;</TD></TR><TR><TD CLASS="quote">rpms?
also y do hondas rev so high when freeway cruising? short gears?</TD></TR></TABLE>
you should be around 3000rpm at 60mph in 5th if its an LS trans
Edit: To the pic above. that only proves that its an LS engine from 90-93. not whether its 90-91, or 92-93.
Old Sep 27, 2008 | 05:26 PM
85crx509's Avatar
it does have the resistor box intact and connected
Old Sep 27, 2008 | 05:28 PM
85crx509's Avatar
i know but sleepingciv asked for a stamp on the engine and i assumed thats what he asked 4
Old Sep 27, 2008 | 05:35 PM
D16SiHatch's Avatar
yea thats fine. and since the box is there, that means it could either be a stock obd0 engine , or possibly an obd1 engine that someone simply used an obd0 dizzy, obd0 injectors, and then retained the box. which is quite common. So at this point i wouldn't feel confident in saying its a 90-91 trans for sure. perhaps theres some other way to differentiate the two that i am unaware of. I guess you could take the trans off and measure the input shaft. i'm unsure however of where it is you need to measure from exactly. And since the difference is only 1/16" an inch, you would want to measure as accurately as possible.
Old Sep 27, 2008 | 05:49 PM
85crx509's Avatar
ok. from ever1's input im gonna assume the engine and tranny are stock from a 90 teggy.. just so i can start ordering parts.
thanks 2 every1
Old Sep 27, 2008 | 06:00 PM
shaggyeg6si's Avatar
Look at the casting date on the head, assuming thats the original head on the original block
Old Sep 27, 2008 | 06:10 PM
85crx509's Avatar
im pretty sure they swapped the valve cover.
seeinghow the older integra motors dont have a huge indent where the spark plugs go
obd0
looks like a b20 valve cover to me
Old Sep 27, 2008 | 06:17 PM
Cable trans....
Old Sep 27, 2008 | 06:25 PM
85crx509's Avatar
Default Re: (shaggyeg6si)
y b20 though?
85crx509's Avatar
yes to cable trans.
Old Sep 27, 2008 | 06:35 PM
thats just the valve cover that came on the crv's. probably changed. can you get a clear shot of the front side of the head? right above the header? that is where the casting marks are, telling us what head it is, and when it was made.
Old Sep 27, 2008 | 06:36 PM
look on the head for a stamp it will say P??
b20-valve cover
http://is.rely.net/1-4533-5036...w.jpg
Old Sep 28, 2008 | 01:25 PM
85crx509's Avatar
these are the stamps i found on the motor right above the headers from left to right
