Help: How to install sway bars
Old Sep 27, 2008 | 12:59 PM
91EF919's Avatar
Default Help: How to install sway bars
Okay i am a noob, i don't know how 2 install a front sway bar. I have a 91 civic std hatch. I have trouble putting it in, i dont know which way it goes. Can someone Show me how it should look and how 2 put it in. I also got a DA rear sway bar, i know how 2 do that one, just make holes in the trunk where the bolt should go.
Old Sep 27, 2008 | 05:42 PM
91civiccross's Avatar
Default Re: Help: How to install sway bars (91EF919)
I believe there is only one way to put it in. Duplicate the way the stock one was in.
If you search for front sway bar, I believe there are some pictures showing how it sits on the car.
Old Sep 27, 2008 | 10:01 PM
Tyson's Avatar
his STD hatch did not have a front swaybar.
you need the brackets from a EF that came with a front swaybar. DA ones dont work.
and yeah, it only goes in one way. you can snake it over the exhaust and shifter linkage if you have enough ground clearance. just try.
Old Sep 28, 2008 | 07:27 AM
91EF919's Avatar
Default Re: Help: How to install sway bars (Tyson)
ok. I got the bracket for the rear sway bar.
jdm_special
23
May 19, 2018 07:35 PM
Civichatch2k
Suspension & Brakes
Feb 1, 2009 11:50 AM
EJ1 wilcox
Suspension & Brakes
23
Mar 14, 2006 12:49 PM
wdskuk
Sep 5, 2003 10:47 AM
Andrew 825SM
Jul 7, 2003 01:19 PM
