Weird Headlight/Turn Signal Problem...
Ok i have done so many things to try and fix this, and no luck..So my headlights don't come on, but my high beams do..AND my turn signal sound keeps clicking even when im not turning. When i am turning it goes to normal speed, but as soon as im straight again, it clicks and clicks, untill it burns out the fuse...Can anyone give me suggestions?? I just tried replacing the headlight arm stalk, and still same symptoms...any help would be appreciated, im quite tire of changing fuses!!!
weird. but the fuse would only pop if there is a surge or a short.
Don't the low beams have their own fuses? I think they do. Check for that.
Maybe try a new turn signal relay to see if that fixes them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 »</TD></TR><TR><TD CLASS="quote">weird. but the fuse would only pop if there is a surge or a short.
Maybe try a new turn signal relay to see if that fixes them.</TD></TR></TABLE>
Yeah they are all fine..Maybe ill try a new relay...Thats right next to the Blinker box right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 »</TD></TR><TR><TD CLASS="quote">Yeah it's under the dash in the fuse panel area. It's just a black, square box if I remember correctly.</TD></TR></TABLE>
Ok becuase i tried replacing the blinker box too, which is what is making the sound, and nothing still makes the sound...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil_Eg »</TD></TR><TR><TD CLASS="quote">News flash, now my whole cluster is out, no backlighting, and my climate control is out as well...Any ideas?</TD></TR></TABLE>
Theres a fuse for that, it probably went out.
Replace it
Replace it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantoM.DA »</TD></TR><TR><TD CLASS="quote">
Replace it</TD></TR></TABLE>
Damn whats burning everything out like that?
Well I checked every fuse, and everything is good...But i still got no cluster lights or climate control..AND the beep that reminds you that you left your lights on is not working..idk if that means anything or not.
ultima.maniac
May 18, 2008 05:06 AM
beep, blinker, burns, civic, fuse, headlights, headlightturn, highlander, honda, integra, problem, s2000, short, signal, turn
