GSR running like balls...help
Old Sep 27, 2008 | 10:12 AM
Integra_drk's Avatar
Default GSR running like *****...help
Alright, my car is a 95 ls with gsr motor. The head is built and car is tuned on neptune. I drove home when night and the car was driving fine. I went to start it in the morning and it was running like ***. The cel is on and the car idles really bad and almost wants to die. When I try to check the code, the light just stays solid. If I could atleast find out what code it is, I would have something to go on. Any ideas? Thanks
Old Sep 27, 2008 | 01:27 PM
FuNkDrSpOt's Avatar
Default Re: GSR running like *****...help (Integra_drk)
Gotta find out the cel. That's the ONLY tip. Yeah, it doesn't blink like it should but maybe then it's time to invest in a code reader.
Old Sep 27, 2008 | 04:14 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk &raquo;</TD></TR><TR><TD CLASS="quote">Alright, my car is a 95 ls with gsr motor. The head is built and car is tuned on neptune. I drove home when night and the car was driving fine. I went to start it in the morning and it was running like ***. The cel is on and the car idles really bad and almost wants to die. When I try to check the code, the light just stays solid. If I could atleast find out what code it is, I would have something to go on. Any ideas? Thanks</TD></TR></TABLE>
Hmm..
So when you try to jump the code off.. you get nothing stay's solid..
Last time when that happened to me, turned out to be a BAD ecu.
Old Sep 27, 2008 | 05:42 PM
Default Re: GSR running like *****...help (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
Hmm..
exactly what I was thinking, I bought another ecu and tried it out but same ****. So it has to be something else
Old Sep 27, 2008 | 05:46 PM
Jimmy's Avatar
Global Moderator
exactly what I was thinking, I bought another ecu and tried it out but same ****. So it has to be something else</TD></TR></TABLE>
Alright.. Ummm what are you using to try and jump the ecu connector off.. are you 100% sure your getting solid contact inside the connector?
That's the only other thing i can think of..
crxowner
Oct 12, 2011 02:54 PM
crazyguy
Aug 21, 2007 10:01 AM
dezerte
Mar 18, 2007 10:54 PM
nteg4280
Jul 21, 2006 03:16 PM
Andrewm224
Jul 4, 2005 12:19 AM
