just installed my .......
i just installed my injen short ram intake and i had a few questions to those who have it does it sounds like sometimes u hear metal hitting metal
and also when i changed my coolent hose some of it come out and now it seems like my fan is on more than b4 is there a way to check this??????? but temp meter is normal no check engine idle is normal
it sounds amazing
heres the pic
and also when i changed my coolent hose some of it come out and now it seems like my fan is on more than b4 is there a way to check this??????? but temp meter is normal no check engine idle is normal it sounds amazing
heres the pic
Congrats. The metal2metal noise can be something loose as far as brakets go. Look at them 1x1. Let the car cool down and check the level on your radiator by removing your radiator cap. You should see some right on there. Then check the radiator reservoir as well. There are 2 lines on that reservoir, one says full if I recall right and one says low. It should be between those 20. Hope it helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Micha »</TD></TR><TR><TD CLASS="quote">Why does he need mods to tune?
You would be surprised what these cars do with just tuning. </TD></TR></TABLE>
You need bolt on mods (race header, intake, exhaust, any combination of the three) to see positive gains after a Hondata reflash.
We don't have KPro.
We don't have KPro.
I installed a aem sri on my si and heard noise too, but I think its the way it sucks in air, as for the coolant same here lost coolant but refilled the spare bottle after a week of driving b\c it was low and it drives fine now.
Modified by seeker07si at 7:23 PM 9/27/2008
if u have the original coolant in there, just go to the dealer and ask which brand they use. but i think honda makes their own brand but im not too sure about it. but i heard that mixing different brands of coolants is a bad thing
Hi Micha
Hondata says that you should have at least an intake or an exhaust before the reflash, otherwise you'll lose power up top.
streetsmart
Sep 3, 2007 01:16 PM
Nocturnal
Feb 21, 2004 07:17 PM
