Will 97 Civic HX axles fit Si cable trans
Here's what I found from the NAPA website:
Si axles
Item#: NMD956108
Product Features:Compressed Measurements Used To Determine Length.
Compressed Length:35 9/16"
Spline Count of Inner Joint:25
Spline Count of Outer Joint:26
HX axles
Item#: NMD956167
They have different part numbers but the same measurements
Si axles
Item#: NMD956108
HX axles
Item#: NMD956167
if it were the same year Hx then i could tell you for sure that they would work. however since they are newer Hx axles i havent a clue if they're identical or different in some way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedhfrex »</TD></TR><TR><TD CLASS="quote">check the spline count on both axles if the match up then you should be good</TD></TR></TABLE>
Good point, this is what I found on the Rock Auto site
Si axles:
A-1 CARDONE Part # 604002 {Reman CV Half-Shaft Assembly / Overall Length=23.6875" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Right
A-1 CARDONE Part # 604003 {Reman CV Half-Shaft Assembly / Overall Length=35 9/16" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Left
HX Axles:
A-1 CARDONE Part # 604060 {Reman CV Half-Shaft Assembly / Overall Length=35 9/16" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Left; w/ABS
A-1 CARDONE Part # 604064 {Reman CV Half-Shaft Assembly / Overall Length=24.5" Outboard Splines=26 Inboard Splines=25 Inboard Joint Type=Male}
Front Right; w/ABS
So they should fit right? Both have the same spline count.
Si axles:
Front Right
Front Left
HX Axles:
Front Left; w/ABS
Front Right; w/ABS
cityofcaterpillars
Apr 16, 2016 03:24 PM
bluez6
Aug 27, 2006 12:49 PM
