Cyl #2 misfire
Old Sep 26, 2008 | 11:57 AM
916B18c1's Avatar
Default Cyl #2 misfire
hey HT i threw a code the other day, turns out is was my cy #2 misfire.
poped the hood to investigate, and it turns out my #2 spark plug wire does not sit flush against the valve cover like the other 3. I pulled out the wire and and put it back, put some wieght on it, but the mother [freak]er wont go in all the way.
i reset the ecu and the car runs fine, but wtf? im kinda worried something worse could happen any ideas?
Old Sep 26, 2008 | 11:59 AM
Jimmy's Avatar
Global Moderator
Pull the plug out.. take a look at it.. and make sure it's screwed all the way down..
Old Oct 27, 2008 | 09:06 AM
916B18c1's Avatar
Default Re: (Jimmy)
woa, sorry for the late response.
when reinstalling plug #2, it doesnt seem to thread, or better yet, "catch". i guess that means its stripped huh?
Old Oct 27, 2008 | 10:27 AM
CompanyFlow's Avatar
Default Re: (916B18c1)
If it doesn't catch then its stripped. It also means you're screwed.
Old Oct 27, 2008 | 11:16 AM
kronikSLOW's Avatar
Default Re: (CompanyFlow)
not screwed your never screwed. you just have to do alot more work. like pull your engine apart and weld in a piece of metal and then drill and tap it. but it whould be easier to buy a new block. but i guess this other option is very not reccomended and have never done it but seen it done get a socket tap it to thread your spark plug into it and then hammer that socket into your engine. again NOT RECCOMENDED BUT WILL WORK.
Old Oct 27, 2008 | 09:24 PM
916B18c1's Avatar
Default Re: (kronikSLOW)
you mean a heli coil?
is there anyway of doing this without removing the head?
Old Oct 27, 2008 | 09:37 PM
demonwerkz's Avatar
if u tap it then no .. u have to take the head off. but there in another option. u can get a reverse thread chaser. if that doesnt help. then u will have to do the insert and tap. try not to use helicoils if possible. i normally use the copper inserts. same concept of helicoil but alot atronger and safer.
Old Oct 28, 2008 | 08:50 AM
Um..having to pull the head and re thread it means you're screwed.
Old Nov 8, 2008 | 02:51 PM
916B18c1's Avatar
Default Re: (demonwerkz)
that's what i was thinking. since the spark plug boot isn't sitting flush, the threads are probably just dirty. they have a reverse thread chaser at kragen for $50. what do I need, 14mm?
PsXtreme
Jun 26, 2016 01:43 PM
xSOHC
Oct 15, 2013 12:08 PM
smoovekriminal
Aug 1, 2007 08:40 PM
TeayotaSoupra
Sep 20, 2005 12:13 PM
GSR-REX
Jan 10, 2003 07:40 AM
