1000 dollars to build head
Old Sep 26, 2008 | 11:45 AM
namewasdallas's Avatar
Default 1000 dollars to build head
is it possible to build a b16 head for 1000 dollars?
Looking to get good mid range between 3700-6500 rpms, usally thats were im at driving around the towns near me.
is it possible to find cam gears, valve train and cams, for 1000 id get new vavles springs and retainers new , used skunk2 cams or something that makes nice mid range, and used aem or skunk2 cam gears. Im geting a tri Y header design running threw my 2.25 exhaust. Not looking for any numbers just some mid range. like everyone says numbers are just numbers and its all about how it drives.
Old Sep 26, 2008 | 11:53 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 1000 dollars to build head (namewasdallas)
here's what you do: Buy a set of buddy club 3 cams, cam gears and their valvetrain, take your head to a machine shop, get them to install the springs and cams, do a valve job if needed and check/freshen the head. You'll have what you want.
Old Sep 26, 2008 | 11:57 AM
Default Re: 1000 dollars to build head (00Red_SiR)
ill have synapse turbo install everything for me, there my local shop and do great work, do buddy club 3s make good mid range?
ive herd about people using em but never looked at them. is it possible to get all that for under 1000 dollars, if not would the cams work with other cam gears and valve train?
Old Sep 26, 2008 | 12:01 PM
00Red_SiR's Avatar
All Motor Mentor
buddy club 3's are considered to be the "midrange cams" by most people and $1000 should cover what you want. Search buddy club or BC 3's.
Old Sep 26, 2008 | 12:05 PM
American.Graffiti's Avatar
^ he is correct.
Talk to Combustion Contraption. Get a 3 angle PnP job for like 300. You can buy the rest of your valve train for something around 700.
Old Sep 26, 2008 | 12:07 PM
yeah i just found in the market place a really good deal i think tell me what you think. RS Camshafts B16/18 Spec III + w/Cam Gear and Valve Springs: $731.00
the rs cams the spec 3's right?
i saw other people selling used ones for 300 for cams or 450 with cam gears, but i figure i can find cam gears used for like 80 . now can i just drop those cams and valve train in and tune or do i need to ugrade my fuel rail and injectors, cause i just got stock, im gonna tune on hondata, i dont have money to do any porting or anything, or will the head not flow enough for the cams to work right?
Old Sep 26, 2008 | 02:07 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by namewasdallas &raquo;</TD></TR><TR><TD CLASS="quote">
the rs cams the spec 3's right? </TD></TR></TABLE>
no, the BC 3 or Buddy Club 3 cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by namewasdallas &raquo;</TD></TR><TR><TD CLASS="quote"> now can i just drop those cams and valve train in and tune or do i need to ugrade my fuel rail and injectors, cause i just got stock, im gonna tune on hondata, i dont have money to do any porting or anything, or will the head not flow enough for the cams to work right?</TD></TR></TABLE>
Drop them in and tune yes as long as they're done by someone who knows what they are doing. The head will flow more than enough for these cams and then some. No need for fuel rail or injectors, Hondata
Old Sep 26, 2008 | 02:19 PM
sweet deal, so im trying to peice a kit together right now, i found a set of bc3's for 120 im winning right now
Old Sep 26, 2008 | 02:22 PM
00Red_SiR's Avatar
All Motor Mentor
you can search on the classifieds here as well for some good deals.
Old Sep 26, 2008 | 02:36 PM
Rocket's Avatar
That's too bad, I had some new in box "BC3" from UGR that I couldn't sell for $20. . Can barely give these things away.
Old Sep 26, 2008 | 03:11 PM
Default Re: 1000 dollars to build head (Master of the Universe)
these the same cams you were trying to sell http://cgi.ebay.com/ebaymotors...68765
Old Sep 26, 2008 | 03:29 PM
Rocket's Avatar
Same same.
You search hard enough you might find someone will give them to you for free.
Old Sep 26, 2008 | 05:30 PM
don't get my hopes up i don't think anyone will be giving me free cams, but if there is god damn ill even toss them 100 bucks + shippin lol. i decieded im going to spend the money and build the head.
Old Sep 26, 2008 | 09:31 PM
racebum's Avatar
$450 cams
$150 3 angle valve job
$230 valves {i used ferrera 6000}
$40 deck head
16 new guides x $3 ea = $48
springs, locks and retainers $250-350
= $1100 ish and that's doing everything, used cams would have the deal under a grand
Old Sep 27, 2008 | 07:39 AM
Default Re: 1000 dollars to build head (idrivesideways)
yeah im goign to start geting everything together,
i figure im just gonna go with buddy club 3's there came gears and valve train for 700 or so, then just get some tunning software.
hopefuly these cams will last like 100,000 miles i dont plan on changing anythign after i install em
Old Sep 27, 2008 | 08:05 AM
CUTTERSPOOL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by namewasdallas &raquo;</TD></TR><TR><TD CLASS="quote">ill have synapse turbo install everything for me, there my local shop and do great work, do buddy club 3s make good mid range?
ive herd about people using em but never looked at them. is it possible to get all that for under 1000 dollars, if not would the cams work with other cam gears and valve train?</TD></TR></TABLE>
x2
Tennant
Jan 9, 2011 03:37 PM
ef-hatchcrap
13
Mar 10, 2010 10:28 PM
Topdawgg
Mar 31, 2009 01:13 PM
NaKnAmAn
May 30, 2008 04:37 PM
