Got some plugs left over on my H2b swap???
that last plug is for the o2 sensor...you can see where it clips onto the bracket and will go the exhaust. also, the second picture (right plug) looks like it could be for the knock sensor. im not 100%, but if it only has one wire, its likely. the ground cable goes to that bolt you have loosened in the middle of the 3rd pic. and the connector by the thermostat looks like it may go up to a plug on right to the right of the vtec solenoid plug. hope that helps.
Modified by philafelman at 2:10 PM 9/26/2008
skUnK2jdm
10
Feb 9, 2008 10:00 PM
97civic123
Jul 30, 2006 05:19 PM
chads
Jun 4, 2005 02:32 PM
