Remove side skirts
Old Sep 26, 2008 | 05:30 AM
Decaf's Avatar
Default Remove side skirts
i have a 94 ex coupe, and i would like to know the right way to remove/ put on side skirts without braking the clips. also what years are sideskirts interchangeable? what about hatch skirts fitting coupes?
thanks in advance
Old Sep 26, 2008 | 08:28 AM
carlosacasa26's Avatar
we don't just give titles out
Default Re: Remove side skirts (Decaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Decaf &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 ex coupe, and i would like to know the right way to remove/ put on side skirts without braking the clips. also what years are sideskirts interchangeable? what about hatch skirts fitting coupes?
thanks in advance</TD></TR></TABLE>
About the side skirts being removed I think it the same prosses as an accord.
https://honda-tech.com/zerothread/2378549
As for the side skirts fitting I not sure. I think its only 92-95.
Old Sep 26, 2008 | 10:22 AM
kojack_0's Avatar
1. unscrew two screws from the front wheel well.
2. unscrew plastic screws from the bottom of the sideskirts.
3. pull sideskirt towards the rear wheel.
4. remove white plastic clips.
*to put it back you have to put the white clips on the sideskirts first. it should push right in.
when it comes to interchangeable:
92-95 coupe to 96-00 coupe.
92-95 4dr to 96-00 4dr.
92-95 hatch to 96-00 hatch.
they are all different sizes.
when putting a 96-00 sideskirts on a 92-95 you will NOT be able to use all the white clips [about 3] but ALL the plastic screw will screw under the sideskirts.
my2ndaccord
Sep 16, 2010 10:09 AM
dcforgod
Oct 8, 2008 12:20 PM
LaEzEnT
Apr 23, 2007 08:08 AM
hb_guy
Apr 13, 2007 05:36 PM
LordoftheAccord
Apr 14, 2003 09:36 AM
