oem blocks = nitride/ nitrate coating on cylinders? Gone after you overbore?
Old Jul 26, 2002 | 03:04 PM
Black R's Avatar
25 Year Member
Default oem blocks = nitride/ nitrate coating on cylinders? Gone after you overbore?
Ok, here's the story:
Local buddy slowly built up his gsr swapped ek... to the point that it eventually had ctr cams, jdm itr pistons, jdm 4-1 header, and itr head/ IM/ tb, etc.....
With fuel tuning only, we were able to coax 180whp out of that setup.
The pistons were put in by a local honda-tech with 20+ years experience working on these cars...
Now here's the weird thing:
He's burning oil like crazy. Like 1/2qt per week. The tech crosshatched the cylinders before putting the new pistons in... and supposedly did it by the book. He also broke the motor in very gently, changing the oil often, and didn't go over 4k rpms for 2k miles, only going up by 1k increments... He really babied it during the break-in.
He's about to sell the car, annd wants to put something in there super reliable that won't smoke... He talked to another honda tech who speaks to the national hotline for honda tech's all the time... he asked them about this particular rebuild, and they told him that if the factory nitride (or was it nitrate?) coating on the cylinders was removed through overboring or rehoning, then the engine will smoke...
Now I know many here have gone with overbore/ aftermarket ones to get higher or lower compression...
Have any of you heard of this cylinder wall coating thing before?
Are you guys burning oil like crazy?
And if you go with a sleeved/ rebuilt motor, would it make sense to send the block to someone like Swain Coatings, so they can put a new coat of whatever nitrade/ nitride, etc?
Old Jul 26, 2002 | 03:09 PM
tonyxcom's Avatar
Default Re: oem blocks = nitride/ nitrate coating on cylinders? Gone after you overbore? (Black R)
off the top of my head I would look at the pistons. either then need to be oversized and they aren't or one/few of the rings may be damaged from installation.
thats off the top of my head.
I would try a REAL leak down test and see what you find.
Old Jul 26, 2002 | 03:10 PM
sgT's Avatar
sgT
no coating.
that motor was poorly built.
Old Jul 26, 2002 | 03:44 PM
SuperTwinz's Avatar
Default Re: oem blocks = nitride/ nitrate coating on cylinders? Gone after you overbore? (sgT)
no coating.
yup
Old Jul 26, 2002 | 03:54 PM
MackSpeed-616's Avatar
there is your prob.
not the cylinder coating.
Old Jul 26, 2002 | 04:05 PM
Rob :190:'s Avatar
Default Re: oem blocks = nitride/ nitrate coating on cylinders? Gone after you overbore? (BustaNutt-616)
there is your prob.
"They dont make them like they used to..."
97CWITR
Nov 18, 2012 06:11 PM
gsrob
Jul 31, 2007 06:40 AM
michielGSR
Apr 10, 2007 03:38 AM
BLK99VTECR
Sep 2, 2003 02:12 PM
guyuenvy
Mar 5, 2002 12:19 PM
