Pistons
Old Aug 14, 2003 | 05:10 PM
BLK99VTECR's Avatar
Default Pistons
when going with a OEM CTR CAMs set up on a jdm b18c, which pistons would be best: Soon balanced JDM ITR, USDM ITR or Civic Type R pistons. Im trying to keep everything OEM with a decent HP and TQ and hopefully a mid to low 1/4 time with I/H/E.
Old Aug 14, 2003 | 05:26 PM
Cone's Avatar
Default Re: Pistons (BLK99VTECR)
CTR Will give the highest CR (12:1 or somthing like that). So I guess those would be the best for power if you tune it well. Spoon balanced ITR pistons aren't really worth the $$$...
-Andrew
Old Aug 14, 2003 | 07:04 PM
JDM_Risa's Avatar
is this a street car or race car? 12:1 i think is high for street i would try to aim around 11:8 and below I am planning to use JDM ITR piston oversize and shot-peened my rods with all new bearings tuning is gonna be key
IS this a a jdm type R motor 11:1 or JDM GSR motor 10:6 either way your stock bottom end is pretty good you don't need to swap out piston just mill the head and run thin head gasket
Old Aug 14, 2003 | 08:25 PM
BLK99VTECR's Avatar
Default Re: Pistons (GunMETAL_TEgRa)
its a JDM GSR. Its gonna be daily driven so if a 12 compression is too high then i want somthing milder but still making a noticeable difference.
Old Sep 2, 2003 | 12:20 PM
BLK99VTECR's Avatar
any more recomendations?
Old Sep 2, 2003 | 01:18 PM
sander's Avatar
2.7(p/t)
if your looking for under 12:1 then go with a JDM ITR piston.
-sander
Old Sep 2, 2003 | 01:35 PM
mr.beeks's Avatar
Default Re: Pistons (jazzyfoo)
hope this info helps
http://www.c-speedracing.com/h...c.php
Old Sep 2, 2003 | 02:12 PM
91tegrals's Avatar
yeah that compression calculater helped me a lot on figuring out my compression..
stonet149
12
Nov 2, 2008 09:29 PM
philafelman
28
Sep 28, 2003 11:37 AM
guyuenvy
Mar 6, 2002 01:14 PM
guyuenvy
Mar 5, 2002 12:19 PM
comptechgsr
Jun 25, 2001 01:02 PM
