Changed 02 sensor can't get rid of code 1...
Old Sep 25, 2008 | 07:34 PM
wakaranai's Avatar
Default Changed 02 sensor can't get rid of code 1...
Done.
I wired the 02 sensor directly to pin c16 and my CEL is gone. Thanks for the help folks. I guess that means that my 02 wire is screwed somewhere in the harness.
Modified by wakaranai at 10:05 AM 9/30/2008
Old Sep 25, 2008 | 07:50 PM
acmoc's Avatar
Default Re: Changed 02 sensor can't get rid of code 1... (wakaranai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai &raquo;</TD></TR><TR><TD CLASS="quote">I checked my grounds and all the wiring associated with the 02 sensor and everything looks legit. I found several threads from years ago in which people had this issue and it was never resolved--at least on H-T. I know it's a code 1 and not a 10 because the blink is very quick. Any help greatly appreciated.</TD></TR></TABLE>
Installed a new one?
Reset your ECU?
Old Sep 25, 2008 | 09:42 PM
wakaranai's Avatar
Default Re: Changed 02 sensor can't get rid of code 1... (acmoc)
Well, I hate to sound obnoxious, but I wouldn't have posted if I didn't do these things. But given the amount of ignorance on the site, I should have been more explicit.
Here's what I have done:
-Changed 02 sensor with brand new Bosch one
-Reset ECU by pulling hazard fuse
-Also disconnected battery to reset""
-loosened and tightened thermostat ground, which apparently can confuse the ecu and makes it think the engine is running lean
-Checked the wiring/plugs to the sensor--all are physically fine...
Modified by wakaranai at 11:28 PM 9/25/2008
Old Sep 25, 2008 | 09:48 PM
sleepingciv's Avatar
One of my buddies had this prob just like you do. He ended up running a wire from the o2 to the ecu. I assume its a single wire and not a 4 wire? Ya didnt mention that
Old Sep 25, 2008 | 09:54 PM
wakaranai's Avatar
Default Re: Changed 02 sensor can't get rid of code 1... (sleepingciv)
Yeah, it's an OBD-0 setup so it's a one wire 02 sensor. I am running a stock SOHC ZC in CRX Si. The only difference between the d16a6 and the ZC is a more aggressive cam. I doubt this alone would destroy the 02 sensor in 15min...
What did your friend do exactly? I have to get this thing smogged asap. Thanks in advance.
Old Sep 25, 2008 | 09:58 PM
ya i wouldnt think the zc would do that either you might have gotten a bad o2, i just threw one of those in my car also and it works fine with my 12.1 compression ..anyway
he ended up running a whole new wire from his new o2, didnt use any stock wiring, just a new wire straight to the ecu
Old Sep 25, 2008 | 10:05 PM
wakaranai's Avatar
Oh I see. So he just plugged/pinned a wire directly into the ecu. Hmmm...I might have to try this.
Old Sep 25, 2008 | 10:06 PM
hell its worth a shot man by the way its pin c16
Old Sep 25, 2008 | 10:10 PM
wakaranai's Avatar
cool thanks man. Any other tips appreciated
Modified by wakaranai at 11:27 PM 9/25/2008
Old Sep 26, 2008 | 08:22 AM
wakaranai's Avatar
bump
Old Sep 27, 2008 | 12:38 PM
ef yu's Avatar
had a similar problem in my HF. put a si ecu in my car. o2 sensor cel came on. put in a ls ecu and its gone. try another ecu brah
Old Sep 27, 2008 | 01:36 PM
90sedan's Avatar
Default Re: Changed 02 sensor can't get rid of code 1... (ef yu)
Like mentioned above try bypassing the harness and wiring it directly to the ecu. If that does not work, try replacing the ecu with a known good one.
Old Sep 27, 2008 | 02:25 PM
wakaranai's Avatar
Default Re: Changed 02 sensor can't get rid of code 1... (90sedan)
Cool. Thanks for the tip. I'll replace the ECU first, then if that doesn't work it's rewire time.
Old Sep 28, 2008 | 04:04 PM
wakaranai's Avatar
So it wasn't the ECU Next up is wiring. Any tips on what type to use in particular? Voltage etc?
Old Sep 28, 2008 | 05:16 PM
tico's Avatar
just a thought bro is ive heard bosh isnt a very good o2 sensor. i would pay the extra and get a denso not to mention as stated be fore u might have gotten a bad sensor
Old Sep 28, 2008 | 05:41 PM
wakaranai's Avatar
Default Re: (tico)
Yeah, I guess I could try another one. The problem is, I lost the receipt. I might be able to show the people at kragen that I'm still getting an 02 code after replacing it. Most of the guys at the local Kragens are Honda guys, so they might understand.
I am surprised that Bosch isn't considered a "good" 02 sensor. Germans rarely make crappy things But the way things are these days, they are probably outsourcing their work and the sensors are made in New Guinea.
Old Sep 28, 2008 | 06:06 PM
tico's Avatar
the way i look at it is that even though it is a german brand doesnet mean it it was manufactured under their quality assurance. thats why i stick with OEM manufacturers for honda.
Old Sep 30, 2008 | 09:06 AM
wakaranai's Avatar
Default Re: (tico)
Fixed.
Old Nov 6, 2008 | 06:27 PM
riftonthemind057's Avatar
Default Re: (wakaranai)
may I ask you what fixed your code 1 I'm having the same problem. I have replaced the o2 sensor with an oem and still getting the code 1. I'm running a d15b2 with si intake. pm6 ecu. lightweight 8 lb. clutchmaster flywheel and stage 1 clutch. I have been racking my brain over this for a long time.
Old Nov 6, 2008 | 09:52 PM
wakaranai's Avatar
Default Re: (riftonthemind057)
I wired the o2 sensor directly to the ECU. There was something wrong with the wiring between the engine bay and the ECU.
Pothole987
Honda Civic (2001 - 2005)
Aug 23, 2011 08:22 PM
ham
Apr 13, 2007 07:43 AM
Dc_Ek
Aug 9, 2006 08:28 AM
HCRX311
Jun 7, 2005 11:55 AM
chambersef8
May 14, 2004 01:12 PM
