b16 block ls head?
Old Sep 25, 2008 | 05:08 PM
smashdippn's Avatar
Default b16 block ls head?
is this a possible? i have an ls with a blown block and am getting a b16 block, wanted to know if it would work for now
Old Sep 25, 2008 | 07:46 PM
Electron00's Avatar
Default Re: b16 block ls head? (smashdippn)
you'd be much better to find another LS block....they're cheap, and you'll lose power with a B16 block....what exactly is wrong with yours? rebuild it
Old Sep 25, 2008 | 08:56 PM
smashdippn's Avatar
Default Re: b16 block ls head? (Electron00)
i threw a rod. i thought about rebuilding it but i dont have the time or the money.
ive been searching for another ls block but cant find any around my area
Old Sep 25, 2008 | 08:59 PM
gtec8285's Avatar
it can be possible but it will be a dumb move to do what i can tell you is to rebuild your ls or buy another block then put that b16 head and you will be happy
Old Sep 25, 2008 | 10:11 PM
smashdippn's Avatar
Default Re: b16 block ls head? (gtec8285)
alright thanks for the advice. any on what i should get for rebuilding? prices would be nice also
Old Sep 25, 2008 | 10:23 PM
MasterLsGod's Avatar
AHAHAHA I WAS THINKIN THE SAME THING HAHA B16 BLOCK WITH AN LS HEAD WOULD BE A CRAZY SUPER STREET DEAL.
Old Sep 26, 2008 | 02:29 PM
Electron00's Avatar
Default Re: (MasterLsGod)
you could go quite a few directions....it depends on what you want your car to do and your style of driving/usage of the car.
1. Get higher compression pistons from a VTEC motor, which can be found fairly inexpensively if you find a good deal. But at that point, you'll want to upgrade your valve train a little bit and then get a chipped ecu to run and tune with. It's not necessarily needed, but tuning will get this setup running right....and that's the goal, correct?
2. Just rebuild it with factory LS internals. And when you say, "I threw a rod"....do you mean, it snapped a rod, busted a rod through your cylinder wall, or what? This would be the most cost effective route. I would highly suggest going ahead and replacing all preventative maintenance items as well while it's all taken apart. (i.e. water pump, oil pump, gaskets, seals, ESPECIALLY valve seals and get a valve job just to make sure everything is seated and in good working condition after the rod issue).
3. Wait and find a motor that you could get that's used or in a part out. Obviously, you won't know 100% the condition of the engine you get. It could be a "Great engine with Type R internals and blah blah" and then you get it and it's crap....so, be careful and very skeptical with this route.
4. If it were me and I needed the car running ASAP, I would go to passwordjdm and get a B20 long block and throw it in, call it a day. http://passwordjdm.com/B20B-Lo....aspx
So...good luck and good job with asking before you bought one! Just keep asking for good knowledge and you'll get good answers on here.....keep us up to date on this!
Old Nov 14, 2008 | 11:31 PM
mario_pic's Avatar
i made one wow its funny tho lol sounds odd but not like eney honda lol it makes lots of power up and above 9000 rpm just to afraid to go passed lol im going to tune the one we marked up at my buddys shop for jokes and dyno it its a fun motor for the $ lol
Mireku667
May 28, 2007 01:43 PM
chadalac1712
18
Apr 23, 2007 02:29 PM
eg6T
Nov 22, 2004 05:13 AM
hfracer420
Mar 16, 2002 05:15 PM
