What valve stem seal to use with oversized valves?
Old Sep 25, 2008 | 03:13 PM
integra123's Avatar
Default What valve stem seal to use with oversized valves?
I have some oil burning issues. Leak test is good and compression is good as well. All i can think of is the valve stem seals.
When the engine was built I remember I used OEM valve stem seals and the valves were CROWER oversized. They were the .5mm oversized. Could this be the care of my oil burning issue because Im using the wrong valve stem seals? What valve stem seals should I use of that is the case? Thanks
Old Sep 25, 2008 | 03:30 PM
DonF's Avatar
Default Re: What valve stem seal to use with oversized valves? (integra123)
Stock seals. Unless you got oversize stems that I never seen.
Old Sep 25, 2008 | 09:09 PM
Phil M's Avatar
Default Re: What valve stem seal to use with oversized valves? (DonF)
lol
KevinEvo
Aug 6, 2012 07:03 AM
Atomic1
Mar 27, 2010 08:57 PM
E46M3CB
Mar 8, 2004 08:54 AM
se93
Nov 22, 2003 07:02 PM
95LSS
Aug 30, 2003 08:08 AM
