o2 problems
i have a 89 4 dr with just the stock dual point, auto, set up and i replaced the o2 sensor with just the cheap $20 bosch o2 sensor (i got the code 1 from the ecu) and i was wondering if anyone else has had a problem with these in a dual point before. oh i had it replaced under warrenty and not even ten mins later o2 code again. Ive reset the ecu a couple of times and also after i replaced the sensor the second time. any ideas
yea i was thinking there might be a kink in the wire going to the ecu but i cant check that till friday cause i live in texas and i left the dvom on the dash and when i came out after work and it was a wee bit deformed and dont work anymore
If the wire is intermittently "grounding out", then it might pass the continuity test with the your DMM. You could always run a new test wire (don't bother routing it too well) just to do a quick test to see if your problem goes away.
Another thing is people complain about the cheap bosch O2 sensors being really unreliable. did you make sure you didn't touch it with your fingers before you installed it?
accordianex
13
Mar 3, 2006 05:30 AM
civicdragger818
10
Jun 23, 2003 11:51 PM
