Camber Kits?
Old Jul 26, 2002 | 01:38 PM
Braco11's Avatar
Default Camber Kits?
Hey Guys,
I got a 96 Accord (4dr) and wanna lower it about an inch and a half. I was wondering if I am gonna need camber kits all the way around, or for only the back? What springs and camber kits would you recommend? Thanks.
Old Aug 2, 2002 | 12:58 PM
forcedaccord95's Avatar
Default Re: Camber Kits? (HatchMan)
I have a 95 accord, ex, I did the eibach sport kit, 1.7 in the back, 1.8 in the rear, looks good! No camber kit needed! I just rolled 50,000 miles on theses tires!What? Who?
[Modified by forcedaccord95, 9:59 PM 8/2/2002]
Old Aug 2, 2002 | 01:02 PM
kurt.'s Avatar
Default Re: Camber Kits? (forcedaccord95)
If you need one... Ingalls.
Old Aug 2, 2002 | 01:06 PM
unltdacc12's Avatar
i had my knuckles bent and shimmed the rear.. cost $120 at local alignment shop
Old Aug 2, 2002 | 03:20 PM
Nick H's Avatar
New User
Default Re: Camber Kits? (unltdacc12)
it is one of those better safe than sorry type situations, you can get it if you want but my guess is that you won't need it with those springs!
Old Aug 2, 2002 | 04:23 PM
Spooch69's Avatar
I got eibach sportlines. I had the springs on for like 1 year. Took it into a shop and had an aligment done. Shop said that the aligment was off a little bit and he said to get a camber kit. But my tires are doing pretty good.
Old Aug 2, 2002 | 05:12 PM
dvp95's Avatar
Default Re: Camber Kits? (Spooch69)
I got neuspeed sports 1.7/1.8 I got an alignment and had like -2 degree negative camber, so I got the progress camber kit. Now im sitting straight up and down. A lil negative on the back but no tire wear. The only reason you really need it is because of tire wear basically. Few other reasons but..
Old Aug 2, 2002 | 06:55 PM
Razor's Avatar
Default Re: Camber Kits? (dvp95)
dvp, you can always use washers in the rear to correct the camber. thats what i did, my rear is perfect but my front has -2 camber but its fine with me.
btw i have neuspeed sports and koni yellows.
Old Aug 5, 2002 | 09:03 AM
Braco11's Avatar
Cool, thanks guys.
Old Aug 5, 2002 | 09:41 AM
dvp95's Avatar
Default Re: Camber Kits? (Razor)
yeah my negative back is fine with me. Is it the negative front that is better for turning? I know that tires wear in front since its FWD.....my back ones are new even though there is negative camber.
Creator
Jan 25, 2010 02:00 PM
justintimetow1n
Jan 4, 2010 10:02 PM
thebigone
Suspension & Brakes
Jun 9, 2009 07:24 AM
morthanh
Jan 14, 2003 06:09 PM
GasHuffer
Aug 1, 2002 03:02 AM
