Speaker Grill Removal
I need to remove the speaker grills in the doors and the rear to put in a set of non blown speakers. I removed the screws on the door grills but there is still something keeping it from coming loose. I pryed on it pretty good but dont wanna brake anything.
How do i get them off?
Also how do i get the back grills off? Havent even tried them so any hint is a decent hint.
Also pics help ALOT! Visual learner onboard.
Using a compass analogy when looking at the speaker cover on the driver's door. There are 4 tabs on (2 on each north & south side) you need to pop out - use a screw driver that to pop out but put a thin towel around it to not damage the trim. For reference the North side had the 2 screws that you removed and the south side has two slide tabs that will slide out when the 4 other tabs are released.
http://www.helminc.com - best $60 you'll ever spend on your car! It has all directions to properly remove and install almost anything on the entire car.
make sure grills are warm and flexible. I cracked one doing it when it was like 70 out, even being careful. Since then I hit them with the heat gun, and then they are flexible enough they just pop right out with a real little straight blade I got with my stihl chainsaw.
Haha if i had a heat gun i would use it lol. Im doing this in the parking lot of the dorms at my college! Gets some funny looks when doing DIY in a parking lot! Thanks btw
wdyno
Audio / Security / Video
Nov 15, 2001 12:59 PM
