Opinions on this port job.
Old Sep 24, 2008 | 03:44 PM
1rude2l's Avatar
Default Opinions on this port job.
Deal is i got a c5 head in a trade. I took the mani off to check out the factory port job and found this. The intake mani is port matched also. I don't believe they do all this at the factory or am i just wrong. Problem is the had has no cam caps. Just want some opinions here. sorry for the crappy pics kinda hard to catch everything. The divider is cut into a knife. Valve guides are rounded. Exhaust side has been touched also. but kinda hard to see with carbon build up.
Modified by 1rude2l at 5:11 PM 9/24/2008
Old Sep 24, 2008 | 11:51 PM
Flashmn's Avatar
Default Re: Opinions on this port job. (1rude2l)
Looks ported, but its hard to tell from those pics, how much and what quality and if they even are, because they're very blurry.....
Old Sep 25, 2008 | 12:20 PM
1rude2l's Avatar
not sure who did it, got a cheap digital camera, i cant for the life of me get them clear as i want.
Old Sep 25, 2008 | 02:36 PM
twinksack's Avatar
* B A N N E D *
Default Re: (1rude2l)
how do you know its a itr head
Old Sep 26, 2008 | 07:14 AM
1rude2l's Avatar
Well it was on a b18c5 block, has dual springs. stamped 98 pr3-2. My best assumption is thats it a type r.
Old Sep 26, 2008 | 08:18 AM
twinksack's Avatar
* B A N N E D *
no of that means its a itr head for sure
Old Sep 30, 2008 | 11:35 AM
1rude2l's Avatar
bump
Old Sep 30, 2008 | 02:36 PM
Ryan#1's Avatar
swirl polished valves? Does it really matter if it's not an ITR head anyway. It's still ported
Old Sep 30, 2008 | 05:50 PM
Fkned's Avatar
Default Re: (Ryan#1)
Doesn't matter how good the port work is the head is junk now since it has no caps.Unless you want to spend more then it will cost for another head that is.
Old Oct 1, 2008 | 12:11 PM
1rude2l's Avatar
/\ thats basically what i was asking. Is it worth it trying to get it fixed or not.
Old Oct 1, 2008 | 12:49 PM
Fkned's Avatar
depends on how lucky you are .Sometimes you can get away with just another set of caps ,but that is very very rare.usually you have to have them re-linebored with different caps and that's around 600-700 a head or 350 a side.
Snailor Built
Jan 29, 2014 10:30 PM
SwappedTURBOegg
Dec 18, 2013 08:37 AM
known
54
Jul 19, 2009 04:12 PM
wesley_925
Mar 31, 2008 05:00 PM
ko
29
Jun 11, 2004 09:43 AM
