clutch engagment adjustment
i just replaced my RPS pressure plate and sprung solid disk with a RPS sprung 4 puck disk and an act extreme plate. before my clutch engaged when the pedel was about 3" off the floor and now it engages when the pedel is just about all the way up. is this the way all act plates are? i have adjusted the pushrod on the master cylinder and tried bleeding the system, is there any other method of adjustment?
thanks
joe
thanks
joe
The only adjustment is in the pedal, probably the pushrod you said you already adjusted. Possibly, you turned it the wrong way. I felt that way about my exedy 3 puck, but I got used to it.
Bleeding the system will actually make it stiffer and disengage sooner.
[713]
Jun 20, 2009 08:23 PM
RTW DC2R
Jun 23, 2006 07:42 AM
