b18b swap
Old Sep 24, 2008 | 02:03 PM
Dawsonty's Avatar
Default b18b swap
hey people i am building a b18b motor and i want to get some good hp like 325-350 I am also going to put a turbo on it, the questions I have is what pistons/rods i should use, also i have a 92 si that im putting this motor into and I want to put on a good head and i dont know what one to use, any help would be great, ohh and what compression is good to run a turbo and for nos thanks
Tyler
Old Sep 24, 2008 | 05:25 PM
geebs's Avatar
Default Re: b18b swap (Dawsonty)
get some aftermarket rods, and some nice forged pistons..
i have eagle rods and cp pistons in my ls/vtec.
if you dont want to go the ls/vtec route, just use the ls head.
you can boost more on low compression.. you can also boost on high 0compression.
id recommend low compression though.. get some pistons within the 8.5 to 9.5 to 1 ratio range..
high compression turbo would be low boost and require a good tune, high octane fuel..
im using a gsr head.. with 9.0 to 1 cp pistons for b18b setup.. compression is like 9.3 to 1 or something because of the head swap..
Old Sep 27, 2008 | 12:38 PM
Dawsonty's Avatar
Default Re: b18b swap (geebs)
what are some good sites that ship to canada? also would u recomend rebuilding the head with some new cams? or should i just rebuild the head and keep the stock cams? any help would be great
ekhatchb18
Aug 7, 2008 10:50 PM
wushubrian
25
Aug 31, 2006 01:52 PM
SOHCD16y8
Oct 4, 2005 06:03 PM
choko
Aug 10, 2005 08:17 PM
HarryB
May 23, 2002 12:15 PM
