Most accurate way of torquing main bolts/studs
Old Sep 24, 2008 | 12:46 PM
lude98SH's Avatar
Default Most accurate way of torquing main bolts/studs
Just as the topic states. Just as on the rod bolts can use the stretch method could you do anything most accurate than a torque wrench to the mains whether your running bolts or studs and nuts.
Old Sep 24, 2008 | 01:16 PM
Turbowa's Avatar
Default Re: Most accurate way of torquing main bolts/studs (lude98SH)
strech is alway's going to be the most accurate way of doing it for the every day person.
Old Sep 24, 2008 | 01:50 PM
lude98SH's Avatar
Default Re: Most accurate way of torquing main bolts/studs (Turbowa)
how would u measure stretch on that though ?
Old Sep 24, 2008 | 02:12 PM
omniman's Avatar
most autoparts stores sell a torque to angle tool for about 10-15 dollars those work great for what your trying to do.
http://www.hexagon.de/tasignat.htm
second one down
http://www.toolsource.com/adva...lemjg
Old Dec 22, 2008 | 04:48 AM
lude98SH's Avatar
but how does that work exactly ? It not like honda gives a spec on that.
Old Dec 22, 2008 | 06:15 AM
PirateMcFred's Avatar
If you wanted to measure bolt stretch on a fastener that's installed into a blind hole then you would have to have a drop mic and a hollow wrench. Fix the mic to something immoveable (like the block) and position it onto the end of the stud with the wrench already installed then turn to yield.
Otherwise use the manufacturer's specified method. If it's like ARP then use their grease and torque to spec with a standard wrench. If it's Honda then oil the threads and pre-torque then rotate the specified degrees afterward.
FWIW IMO rod bolts are more critical than main/head studs.
Old Dec 22, 2008 | 07:15 AM
lude98SH's Avatar
so your basically just measure the stretch by seeing how far it has stretched the end of the stud from the block ?
Also does ARP or honda give a stretch spec ?
Old Dec 22, 2008 | 08:44 AM
I have not seen one for ARP head/main studs. I have seen info for rod bolts but it's easier to get to either end of the fastener.
On F23 and K-series stuff Honda have a torque to xxft/lbs then rotate an additional x˚. It's not a literal stretch spec but it is a little more refined I think.
b20vtech
Feb 23, 2006 07:45 PM
B18_Civic
Aug 19, 2005 07:16 PM
user 98292739
Apr 1, 2005 08:09 PM
crispydee
Jan 9, 2005 01:17 AM
koy
Feb 9, 2002 05:16 PM
