GSR Leathers in 95 EG Coupe
Found a set of Front and Rear that matches my interior. I have heard the fronts will work but not the rears? Is this true? any way of modifying the mounts? Thanks
You need teggie sedan rears, but the will have a gap.
https://honda-tech.com/zerothread?id=2385250
https://honda-tech.com/zerothread?id=2374695
you can use the 2 door integra rears..just make a small hole into the plastic so that the metal part on the top seats could go in and fit..they will be a nice tight fit on top and you will have a little gap on the bottom seat..but trust me it will work..just do it like nike..lol
So both 2 / 4 door GSR Leather seats will bolt right up. Will 2 door GSR's atleast bolt up to the rears but will have the gaps because they are too narrow or is that just with the 4 door rears? Will 2 door GSR's fit at all?
No tiggie 2 dr coupe backrest wont bolt up to a civic coupe or sedan, only hatch's because its a 50/50 split backrest. They have a center hinge and the civic coupe doesn't.
If you have a civic coupe you need a teg sedan backrest cuz its a full bench style backrest and will bolt up to your coupe and lock in the center but you will have gaps on the sides.
rugimpy
Mar 2, 2010 04:20 AM
JDMCRX
Dec 13, 2009 04:55 PM
