p72 ecu w/ hondata s200 problem
Old Sep 24, 2008 | 10:30 AM
b20vtech's Avatar
Default p72 ecu w/ hondata s200 problem
my car does not want to go pass 4,500rpm on idle, but if u drive it, it'll go pass 4,500 rpm like nothings in the way.... it acts as if the launch control is set to 4,500rpm, but i don't even have the clutch swith or stoplight switch install under with the clutch pedal..... do i have to have that for me to be able to rev pass 4,500rpm on idle?? im confuse about this whole thing... please help.
Old Sep 24, 2008 | 11:15 AM
HRTuning's Avatar
Default Re: p72 ecu w/ hondata s200 problem (b20vtech)
If the input that was chosen is always grounded, that would make this occur, or if they ended up changing it so a switch was not necessary.
Old Sep 24, 2008 | 12:11 PM
Spunkster's Avatar
It really all depends on what version of romeditor it was tuned with. You need to talk to your tuner and find out exactly what software was used and how the parameters were set.
Old Sep 24, 2008 | 12:32 PM
b20vtech's Avatar
Default Re: p72 ecu w/ hondata s200 problem (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">It really all depends on what version of romeditor it was tuned with. You need to talk to your tuner and find out exactly what software was used and how the parameters were set.</TD></TR></TABLE>
he said for me to send him the ECU, hondata s200, and the chip that he put in the ecu, he's gonna find out whats going on.
AntMan401
Feb 7, 2007 04:15 PM
rwcdrums
Jun 28, 2006 08:42 PM
crx1856
Oct 25, 2003 04:56 PM
MEANB18
Oct 14, 2003 06:03 PM
Brian_92GSR
Feb 4, 2002 01:00 PM
