Avid Motor Mount Help!!!!!
Old Sep 24, 2008 | 07:37 AM
Manny1987's Avatar
Default Avid Motor Mount Help!!!!!
I picked up some new Avid Billet style motor Mount last week and I cant get them in. Im like an inch off on the drivers side, It seems that I need to move the motor back. I really dont know b/c the valve cover will be really close to the Strut tower. I got an EK with a B18A1 (LS). Does anyone have these mounts that could help me out im out of ideas. I have the tranny mount in im going to go fight with the rear mount now then try the drivers side again.
Old Sep 24, 2008 | 12:50 PM
vtecb18c's Avatar
Default Re: Avid Motor Mount Help!!!!! (Manny1987)
i dont know if this will help. but i had avid mounts for my crx with a b16 and my intake manifold was about only a coiuple of inches away from the firewall so maybe some mounts set the motor back a little bit
Old Sep 24, 2008 | 02:33 PM
Manny1987's Avatar
Default Re: Avid Motor Mount Help!!!!! (vtecb18c)
Thanks for the info ill try the back mount and see what happens.
Old Sep 25, 2008 | 07:38 AM
YZFR6's Avatar
Hey Manny1987,
Sorry I didn't get to this thread sooner. I just came across it. Please make sure you are using the rear transmission bracket ( aka 'L' or 'T' bracket) from a 99-00 Si, as well as the timing belt bracket from a 99-00 Si. From what you are describing, it sounds like you are using the rear bracket off the B18a, which came from an Integra and will totally throw off the engine positioning in your 96-00 Civic. If you still help more help or have any questions feel free to call us at the office. 866-507-AVID. Thanks!
-Franklin
Old Sep 26, 2008 | 01:44 PM
DaveF's Avatar
Default Re: (YZFR6AVID)
need to use 99-00 civic si timing belt mount (3 bolts to block) the DA block mount is a bit shorter and the bolt holes are not on the same angle.
Coach McGuirk
Nov 2, 2008 02:02 PM
too much vtAK
May 17, 2006 09:21 PM
Carson-EK9
Apr 25, 2006 06:36 AM
O16581724 5 2 5
May 30, 2005 10:35 PM
EJCivJdM93
Feb 9, 2005 04:40 AM
