Vtec _E in a 89 4dr EF what do i do with the distributor?
Old Sep 24, 2008 | 07:19 AM
doc1911's Avatar
Default Vtec _E in a 89 4dr EF what do i do with the distributor?
I want to keep the dual point efi but the distributors are different is there any way around this without going total obd1?
Old Sep 24, 2008 | 07:57 AM
crx_si-r's Avatar
Default Re: Vtec _E in a 89 4dr EF what do i do with the distributor? (doc1911)
what you will have to do if you wanna keep obd0 is modify you TD-01U dizzy. you will need to trim the ears, where it bolts to the head. so that it fits.
Old Sep 24, 2008 | 09:03 AM
dem0nk1d's Avatar
do it right! go obd1 and you will never have to worry about a thing afterwards.
Old Sep 24, 2008 | 09:14 AM
sleepingciv's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">do it right! go obd1 and you will never have to worry about a thing afterwards.
</TD></TR></TABLE>i agree with him
but if your low on cash and cant afford the obd1 swap now. you can use you dpfi dizzy you dont need to cut or trim. I know this sounds hillbilly as hell but only us the to side ears on the dizzy. I have ran mine this for about 3 months with no problems. if ya need a pic ask ill snap on for ya to show ya what i mean. But its wise to swap over to the correct dizzy. I just ordered my stuff for the obd1 swap recently so it will be correct
Old Sep 24, 2008 | 09:20 AM
doc1911's Avatar
i think i will modify the distributor because to go obd1 i need wiring harnesses do go from dual point to multi then a wiring harness for the ecu then a harness for the distributor.
This is a dayly driver for me and im out of spare cars i need to do this fast dont have time for a project car
Old Sep 24, 2008 | 09:23 AM
doc1911's Avatar
Default Re: (sleepingciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv &raquo;</TD></TR><TR><TD CLASS="quote">i agree with him
but if your low on cash and cant afford the obd1 swap now. you can use you dpfi dizzy you dont need to cut or trim. I know this sounds hillbilly as hell but only us the to side ears on the dizzy. I have ran mine this for about 3 months with no problems. if ya need a pic ask ill snap on for ya to show ya what i mean. But its wise to swap over to the correct dizzy. I just ordered my stuff for the obd1 swap recently so it will be correct</TD></TR></TABLE>
Yes show me how to do it i have a obd0 5 pin distributor on it right now will this one work? when i slide it on my vtec e the TDC point is way off on the cam as well. is there a certina distributor that works better snap some pics please
Old Sep 24, 2008 | 09:35 AM
Default Re: (doc1911)
ya you 5 pin is fine for this since your car is not mpfi
no top bolt
only the side bolts NOT ran threw the holes
Old Sep 24, 2008 | 09:57 AM
doc1911's Avatar
and the car runs and the timing is correct?
Old Sep 24, 2008 | 11:01 AM
Yep runs like a top no problems
Old Sep 24, 2008 | 11:41 AM
doc1911's Avatar
way cool yea hillbilly but when your broke hillbilly is better than walkin.
Old Sep 24, 2008 | 12:48 PM
IndySporty's Avatar
BTW you can take a reamer or unibit drilbit whatever and ream out the top hole in the dizzy slightly and you'll be able to get the top bolt in I did it the other day with a Y8 dizzy on a Z6 head, worked perfectly after I widened the hole a bit.
Old Sep 24, 2008 | 01:31 PM
doc1911's Avatar
Default Re: (IndySporty)
is there anything else i need to know or watch out for before i attempt this like the AC compressor, power steering or motor mounts?
Old Sep 24, 2008 | 02:12 PM
ef yu's Avatar
i have done this set up before. broke the distributor twice. be careful using that method. the engine vibrates and the distributor may fall out and break the two pin that is spun by the camshaft.
VegasInvasion
Jul 1, 2010 10:49 AM
crxfreak1117
Feb 27, 2008 09:32 AM
TurboAngst
Dec 2, 2007 10:29 AM
civicracer94
Dec 8, 2006 01:28 AM
Power Rev Racing
Jul 27, 2005 05:12 PM
