Need help with running vtec...
Old Sep 24, 2008 | 04:21 AM
fryman's Avatar
Default Need help with running vtec...
Yesterday I bought the P08 I've had my eye on.My cars a 93 civic DX so it didn't come stock with vtec but I have a D15B vtec in it.So I need help running vtec.
What I want to know is:
Does anyone have a wiring diagram for the P08 ecu?
Do I have to do anything special before installing the ecu?
Will I have to get the pins for the ecu harness or are the pins already there?
Old Sep 24, 2008 | 08:31 AM
94EG8's Avatar
Seagull Management
Default Re: Need help with running vtec... (fryman)
You only need to concern yourself with 2 pins, vtec solenoid and vtec pressure switch, the rest doesn't apply to you. You will need to get 2 pins for the ECU. You might be able to get the from honda or go to a junkyard and depin two wires and cut off about a foot wire on each one so you can splice them.
Old Sep 24, 2008 | 09:14 AM
fryman's Avatar
Default Re: Need help with running vtec... (94EG8)
Great diagram,thanks.So the A4 pin goes to the green/yellow vtec solenoid wire and the vtec pressure switch has a black and blue/black wire running from it...don't I have to hook up both of those wires?
Old Sep 24, 2008 | 09:56 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fryman &raquo;</TD></TR><TR><TD CLASS="quote">Great diagram,thanks.So the A4 pin goes to the green/yellow vtec solenoid wire and the vtec pressure switch has a black and blue/black wire running from it...don't I have to hook up both of those wires? </TD></TR></TABLE>
Yes, the blue wire goes to pin D6 and the black wire is a ground. green/yellow as you said goes to pin A4, you can thank katman for the diagram.
Old Sep 24, 2008 | 10:07 AM
fryman's Avatar
Ok so then I just ground the black wire to the frame.Thanks for the help
tofastgsr
Engine Management and Tuning
Oct 26, 2012 06:11 AM
ilovemyb16a
May 18, 2006 12:58 PM
KY
Dec 22, 2004 05:46 PM
AIWFCIATR
Jul 23, 2004 12:11 AM
