breaking up under boost?
Old Sep 23, 2008 | 06:55 PM
twitch27's Avatar
Default breaking up under boost?
So my integra has been sitting for a while. I finally got it running by replacing the distributor, and since then at around 8-10psi it stops making power. Theres almost a gurgling sound. Its never did this before the distributor change. Its idling fine, spools fine, and feels good until about 8psi. Its a odb1 converted from obd0 b18a, with an obd1 b16 distributor. any suggestions? Any help is appreciated.
Old Sep 24, 2008 | 06:24 AM
98vtec's Avatar
moderator emeritus
Default Re: breaking up under boost? (twitch27)
are you able to datalog the event?
plug gap?
what is base ignition timing set at?
Old Sep 27, 2008 | 11:39 AM
twitch27's Avatar
Default Re: breaking up under boost? (98vtec)
Plug gap is at .30, and base ignition timing is set at 16. I would have to call my tuner to datalog the event. I was kinda hoping to solve this problem before I called him out here.
Old Sep 27, 2008 | 01:24 PM
philafelman's Avatar
how long has the gas been sitting in the tank...possibly got some moisture in there?
Old Sep 27, 2008 | 02:51 PM
twitch27's Avatar
Default Re: breaking up under boost? (philafelman)
has new gas.
Old Sep 27, 2008 | 03:12 PM
what replacement dist. did you use, oem or aftermarket?
Old Sep 27, 2008 | 03:14 PM
twitch27's Avatar
obd1 b16 distributor with obd0 plugs.
Old Sep 27, 2008 | 08:06 PM
laziebun's Avatar
i had same issue, close the gap some
Old Sep 29, 2008 | 10:45 AM
havok hybrid's Avatar
Default Re: (laziebun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote">i had same issue, close the gap some</TD></TR></TABLE>
Get a new set of plugs
Set the gap to somewhere between 18-22 . Report back!
Old Sep 29, 2008 | 03:43 PM
twitch27's Avatar
Default Re: (havok hybrid)
Lowered the gap down to .20 and problem solved. weird this has never happened with my old distributor. Thanks for the help though.
Old Oct 2, 2008 | 07:45 PM
twitch27's Avatar
Default Re: (twitch27)
Sorry to bring this back from the dead, but for what ever reason its doing the same thing again. The plugs are now down to .18, is there anyway this could be related to distributor?
Old Oct 2, 2008 | 07:52 PM
laziebun's Avatar
open your dis and check the rotor....your losing spark somewhere so that would be the next thing i would do.
Old Oct 2, 2008 | 08:01 PM
twitch27's Avatar
I cleaned the cap and rotor w/ sandpaper and the same things happening. I may pick up a new cap and rotor tomorrow just to try it out. This is a used distributor that I have on there as well.
Old Oct 3, 2008 | 09:19 AM
Ryan#1's Avatar
What's the condition of the coil? It sounds like you are having to make things easier on it in order for it to continue working. There is also an ignitor in the distributor, they tend to go bad at times too. A high load from a bad or bigger coil can make them go bad too. You should measure the resistance of the coil and see if it's up to par.
Old Oct 4, 2008 | 08:36 PM
twitch27's Avatar
Default Re: (Ryan#1)
I replaced the pickup with one from my old distributer and everything seems to be good. Ill try not to bring this back. thanks
nyckid
Apr 5, 2015 11:28 AM
stackz
Jan 5, 2007 01:25 PM
ej8
Jan 27, 2005 10:56 PM
Built B18ABorC
Sep 3, 2004 05:04 PM
thegreatwhitehope
Apr 20, 2004 05:26 AM
