car wont start not your average problem
Old Sep 23, 2008 | 06:31 PM
93daintegra's Avatar
Default car wont start not your average problem
ok my car stop running the other day and so i find out it was geting any spark, so i took apart the distributor put in a new coil pack and new ignitor and i plugged everything in and still no start i dont know what the problem is any help would be nice .......
PS: ITS NOT THE STARTER AND NOT FUEL PUMP!
Old Sep 23, 2008 | 06:33 PM
seldon's Avatar
Default Re: car wont start not your average problem (93daintegra)
is it rolling over? have you narrowed it down to a spark problem?
Old Sep 23, 2008 | 06:42 PM
Default Re: car wont start not your average problem (seldon)
yea the car cranks like it wants to start but no spark to start the car
Old Sep 23, 2008 | 07:14 PM
LSracing94's Avatar
try a different ECU
Old Sep 23, 2008 | 08:03 PM
frost_0ne's Avatar
Default Re: car wont start not your average problem (LSracing94)
id have to say try your ecu as well.. or check your grounds?
Old Sep 23, 2008 | 11:27 PM
Roofrack's Avatar
i had a problem like that and it turned out being the ecu as well
Old Sep 24, 2008 | 12:18 AM
LSVTEC408's Avatar
check your fuses also and firing order
Old Sep 24, 2008 | 08:16 AM
00GsR-TeG's Avatar
Default Re: car wont start not your average problem (LSVTEC408)
i see that you said you have no spark, try and listen to see if you hear your fuel pump prime. If you dont hear your fuel pump priming, that means that you have no sark and no fuel. MAIN RELAY!!!
Old Sep 24, 2008 | 09:11 AM
System Lord's Avatar
I run a 100 shoot on my 95 gsr & had the same problem after a few passes with the juice. I changed everything you already have. The only things I did you did not is change out the spark plugs I used ngk iridium, and this might sound weird but, unplug your battery entirely for over an hour, I let mine sit unplugged overnight, this will reset the ecu. This could save some green on a new ecu. After all this mine fired up.
Old Sep 24, 2008 | 09:25 AM
PaulMc's Avatar
Painfully Stupid
Default Re: car wont start not your average problem (System Lord)
Deffinitly change the spark plugs, from cranking it so much it can burn them out.
2nd. Check your grounds, it could be an electrical problem, such as a short in the harness, etc.
If I were you I'd try different dizzy, one from a car that you know works for sure, so you know if the dizzy is the problem or not if it works... good luck.
Old Sep 24, 2008 | 03:34 PM
seldon's Avatar
get new plugs and wires
Old Sep 25, 2008 | 01:01 PM
TigerLy's Avatar
i had the same problem with my car a few weeks ago and after doing a complete overhaul it still wouldn't start so i just started from the beginning again and i found out that i damaged my distributor when putting it back in.. the part where it connects to the camshafts it should have like two prongs sticking out and i broke one of mine so there was no timing at all..
Old Sep 25, 2008 | 01:14 PM
kb8thekid's Avatar
Default Re: car wont start not your average problem (00GsR-TeG)
Main fuel relay FTW!!! this was just happening to me, especially as the day got hot, the car would crank but no start, couldn't hear the fuel pump. changed it out and good to go. should be about 50 bucks from dealer or find a used one. in all about a 3 min fix. Dont go out and buy all this expensive other stuff, try the simple things first.
Old Sep 25, 2008 | 05:13 PM
LSracing94's Avatar
Default Re: car wont start not your average problem (kb8thekid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb8thekid &raquo;</TD></TR><TR><TD CLASS="quote">Main fuel relay FTW!!! this was just happening to me, especially as the day got hot, the car would crank but no start, couldn't hear the fuel pump. changed it out and good to go. should be about 50 bucks from dealer or find a used one. in all about a 3 min fix. Dont go out and buy all this expensive other stuff, try the simple things first.</TD></TR></TABLE>
did you read? he said that he knows its not the fuel pump, so therefore he probably hears it priming....which is usually the cause of a faulty main relay. im still going with a bad ECU
Old Sep 26, 2008 | 02:45 AM
gtec8285's Avatar
as everybody else this happens to me this past weekend and the weekend before so the first time bought a new igniter and ignition coil when i put those on my car started after a week it did the same thing so i just bought me a new distributor and it started like a champ..i would prefer to borrow a friends distributor or ecu before you spent alot of money on something you not sure how to fix..but most like it could be the distributor cause you said your not getting any spark plus its understandable knowing that its an old school car
Old Sep 26, 2008 | 08:26 AM
Default Re: car wont start not your average problem (gtec8285)
Still nothing?
Old Sep 30, 2008 | 03:09 PM
kb8thekid's Avatar
hey, thanks for pointing it out.... if your going to point someone out for trying to help, make sure you see everyones post and like you said....read. since i'm not the only one that proposed my solution.
thanks.
Old Sep 30, 2008 | 04:58 PM
hondarat's Avatar
apparently noone else knows how to do any diagnostics soooo..... getting a repair manual and a volt/ohm meter will save you a lot of money rather than changing parts with no results... it will tell you if you have the correct voltage and ohms going into the dizzy and the ecu.. this will tell you your problems with ease. im not being a dick... i used to do the same things and wasted a lot of money. if you cant do that...... borrow a freinds parts.
mlb4046
Jan 23, 2011 03:53 PM
Phantastic
May 28, 2010 03:15 PM
EF909
27
Feb 27, 2010 01:30 PM
cbrracer91586
May 19, 2007 04:31 PM
boostedpleasure
13
Oct 12, 2006 09:10 AM
