97 accord, water leaking under dash
My wifes 97 accord se is leaking under the dash on her feet. It's clear water. I think that its the a/c condensation. I believe the drain came unhooked or is plugged in the dash but not sure how to get to it. Any help would be appreciated.
Thanks
Thanks
Your a/c drainage lines are clogged. Try shooting some air up in the drain (near the front passenger wheel well) or take it to a dealer and have it fixed for around $30.
Also try searching next time if you didn't
https://honda-tech.com/zerothread?id=236088
i tried searching, but came up empty, maybe i did it wrong, or used wrong search words. I blew up through the line with no obstructions, air went through easily.
it's either clogged, or the drain line came out. i believe you have to get behind the glove compartment. I can't explain exactly since this is practically my first day being back here (i haven't been here since late of last year i believe)
I pulled the drain hose off under the glove box and nothing came out, stuck a screw up there and it was like breaking a dam loose. Put the drain back on and it drains like it's supposed to.
Thanks!!!!!!!
Still not sure why blowing from the tube under the car didn't break it loose, but either way it's working now
Thanks!!!!!!!
Nickmg555
Jun 29, 2020 08:32 AM
