What piston do i have???
I'm trying to figure out what brand of piston I have. I bought a car with aftermarket pistons in it. I dropped the oil pan and I don't see any brand thats stamped onto the bottom. But it has the # 22147 stamped on the bottom.
Well gee,let me get my catalogs from every possible piston manufactuer and take a look for you.
How about a clue as to just what motor your talkin about there?B,H,D,K,F?????????
well sounds like they jipped you buddy lol question how do you see the piston from the BOTTOM of the block especially if all you did was drop the oil pan?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeNebseries »</TD></TR><TR><TD CLASS="quote">well sounds like they jipped you buddy lol question how do you see the piston from the BOTTOM of the block especially if all you did was drop the oil pan?</TD></TR></TABLE>Because that's where the Bottom of the piston is.
Have you ever seen a motor being built or apart or even pics?
i didnt know i had to be so specific...
I dropped the oil pan, removed the oil pick up, the oil splash shield. And then I used a light to shine up from the bottom of the motor.
hmm... forged aftermarket piston and rods vs stock cast iron piston and rods.
Yeah you right I got jipped.
These people on here and so stupid to changed to forged components.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fkned »</TD></TR><TR><TD CLASS="quote">Well gee,let me get my catalogs from every possible piston manufactuer and take a look for you.
lol
lol
If you pull the head there might be a number stamped on top...which is where most manufacturers put their serial/part numbers from my experience.
That looks like a job number for a custom piston. Call each major piston manufacturer and ask them if that number fits their numbering system, they will be able to give you specifics for that piston.
I got curious and did a bit of googling. They don't match the design of any SRP, JE, CP, Wiseco, or Aria's piston (or any other that I found) except one.
http://www.manleyperformance.com/dl/2012/pistons.pdf
Ctrl+F for honda (around page 115) Looks like those are a set of older Manley Pistons.
The groove between rings 1 and 2, and the notch at 45 degrees for the wrist pin clip gave it away to me. Also the shape of the pin boss area
Topdawgg
Feb 18, 2007 11:31 AM
Sport_Injected
Oct 20, 2004 02:54 PM
