question about connecting rods
Old Sep 23, 2008 | 01:01 PM
steveharrmr23's Avatar
Default question about connecting rods
i have a b18b1 i am working on ok so here is my question i know yall do not like this but i am building a turbo motor but my question i cause i want to lower my compresion if i put a shorter conecting rod in will it lower my compresion? also wouldn't the shorter rods also make it able to handle higher rpm capability? cause i was informed that have a such a short conecting rod is why a crotch rocket can rev so high was i miss informed
Old Sep 23, 2008 | 01:51 PM
spun Vtec's Avatar
Default Re: question about connecting rods (steveharrmr23)
why the hell would you post this in the all motor forum?
try it, be sure to install a tach that goes up to 15k
Let us know how you make out.
Old Sep 23, 2008 | 01:59 PM
Default Re: question about connecting rods (spun Vtec)
y post it here because forced induction know turbo based stuff so i figure something like this would be better for all motor
Old Sep 23, 2008 | 02:10 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
You are partially on the right track. While an increased R/S ratio will alow you to rev higher, safer, you would also need to port your head for that rpm range and use a cam designed for it. As far as using a shorter rod to lower c/r, yes that would technically work, however it is not the proper way to do it. Also when you start talking about high rpms you run into things like rod stretch and other fun stuff. Stay below 9000 rpms, there's a reason cars don't rev that high.
Old Sep 23, 2008 | 04:09 PM
Default Re: question about connecting rods (2LEM1)
ok thank you for all of you help everyone
Old Sep 23, 2008 | 04:23 PM
ExospeedAMcrx's Avatar
a shorter rod isnt the answer to lowering compression. yes it will lower the compression, but you're just putting the piston at a much lower position and doesnt put the piston at a right compression where it will still be able to have proper combustion.
Old Sep 23, 2008 | 04:50 PM
4g hatch's Avatar
Default Re: question about connecting rods (ExospeedAMcrx)
a longer rod and a shorter crank stroke will give you a better r/s ratio and a more rev happy engine
Old Sep 23, 2008 | 06:24 PM
Default Re: question about connecting rods (4g hatch)
so your say goin with a stock rod length and a shorter crank travel would be more dependable the a stock crank and short rod
Old Sep 23, 2008 | 06:55 PM
PyroProblem's Avatar
Shorter rods will lower your compression, but thats not really the right way to do things...
Shorter stroke, high rod to stroke ratio, and lightweight components all help in high rpm stability...(Like crotch rockets)
Since your going turbo, Id just run the stock geometry bottom end with forged internals and the correct turbo...You wont need to necessarily rev high to make power cause youll have a broad *** powerband... damn turbos
Now go ask yourself...Do you reeeeaaaally want to turbo your engine?
150 hp per liter, 9k rpms, and excellent throttle response doesnt appeal to you?
What about 30 mpg, reliable as hell, easier to work on, and a stockish appearance?
ALL MOTOR FTW
Old Sep 23, 2008 | 07:07 PM
Default Re: question about connecting rods (PyroProblem)
pmed pyro
GeoMetry
May 15, 2014 03:44 PM
gpr
Oct 29, 2012 06:26 PM
Dan GSR
Apr 26, 2004 01:41 PM
94CivSi
14
Apr 15, 2004 04:34 PM
DV98CVC
Sep 20, 2002 08:59 PM
