Honda S2000 Honda S2000
AEM V2 intake system w/air bypass
Old Sep 23, 2008 | 12:16 PM
S2kAllDayGA's Avatar
Default AEM V2 intake system w/air bypass
Does any body have this intake system w/air bypass valve??? If so whats your personal review on it, Oct 1 Im placin an order in for one.....thanks guys n ladies if any
Old Sep 23, 2008 | 12:38 PM
kalm_traveler's Avatar
Default Re: AEM V2 intake system w/air bypass (S2kAllDayGA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2kAllDayGA &raquo;</TD></TR><TR><TD CLASS="quote">Does any body have this intake system w/air bypass valve??? If so whats your personal review on it, Oct 1 Im placin an order in for one.....thanks guys n ladies if any</TD></TR></TABLE>Pretty sure if you even bothered to look at the threads on the first page you'd have found your answer - nevermind using the nice happy red Search tool at the top right of the screen.
Since I'm in a good mood I'll give you a short answer though instead of just flaming.
It works well, bumps up mid-range torque exactly as their dyno indicates and makes a very mean growl. No intakes yet have made any worthwhile peak HP gains however.
Old Sep 23, 2008 | 12:44 PM
Default Re: AEM V2 intake system w/air bypass (kalm_traveler)
I did there where none for the S2000...thanks for your input
Old Sep 23, 2008 | 12:45 PM
papa5murf's Avatar
The bypass valve is useless, don't use it. Unless you're driving through a foot of water (which if you do, you're a complete fool), you shouldn't suffer from hydrolock. However, there is one 'round' hole on the inside of the fender that you need to plug with a piece of rubber or some clear tape.
Old Sep 24, 2008 | 06:25 AM
ExVtec's Avatar
Default Re: AEM V2 intake system w/air bypass (papa5murf)
It was on mine when I bought it.
Seems pretty cool, certainly better than stock. Nice growl, I'll miss it when I go turbo.
Old Sep 24, 2008 | 07:16 AM
papa5murf's Avatar
Default Re: AEM V2 intake system w/air bypass (ExVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">It was on mine when I bought it.
If you miss your AEM intake when you go turbo, there's something seriously wrong in your head.
Old Sep 24, 2008 | 08:25 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">If you miss your AEM intake when you go turbo, there's something seriously wrong in your head. </TD></TR></TABLE>
True That!
The bypass valves suck! I've heard of the foam part being sucked into the motor on some of the older ones.
Not sure it they re-designed after that or not. IIRC they did...
Old Sep 24, 2008 | 10:26 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: AEM V2 intake system w/air bypass (White Smoke)
get an Injen...
Old Sep 24, 2008 | 11:22 AM
HondaKyle's Avatar
</TD></TR></TABLE> You'll miss being slow?
Old Sep 24, 2008 | 11:48 AM
S2KILLA's Avatar
Default Re: AEM V2 intake system w/air bypass (HondaKyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote"> You'll miss being slow?</TD></TR></TABLE>
or if ur kyle, ull miss your car for about 3-4 weeks... hahahhaa im hilarious!!!
Old Sep 24, 2008 | 12:03 PM
HondaKyle's Avatar
Default Re: AEM V2 intake system w/air bypass (S2KILLA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
or if ur kyle, ull miss your car for about 3-4 weeks... hahahhaa im hilarious!!!</TD></TR></TABLE>
Old Sep 26, 2008 | 01:05 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">The bypass valve is useless, don't use it. Unless you're driving through a foot of water (which if you do, you're a complete fool), you shouldn't suffer from hydrolock. However, there is one 'round' hole on the inside of the fender that you need to plug with a piece of rubber or some clear tape. </TD></TR></TABLE>
couldn't be more wrong, i work on quite a few car with water damage by driving in light rain. all it take is right timing and right amount, it doesnt have to be a lake. i live in LA california and there's people hydrolocking there, go figure.
bypass value works great, go hit up google for a video. however the first gen aem value are know for snapping off, mine did
Old Sep 26, 2008 | 03:25 AM
papa5murf's Avatar
Default Re: AEM V2 intake system w/air bypass (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
bypass value works great, go hit up google for a video. however the first gen aem value are know for snapping off, mine did </TD></TR></TABLE>
I've gotta be honest here, my car was slammed, and it was a daily driver. I've driven the car through some very severe rain storms over the years and have never ever had a problem. Even when driving through standing water on the side of the road.
If you have a cold air intake; like I specifically stated, there is one 'round' hole on the inside of the fender that you need to plug with a piece of rubber or some clear tape. If you plug this hole, there is no water runoff into where the filter sits. If you do not plug this hole, water will drip onto the filter. As for the bottom of the filter, there should be no water unless you are submerged in water (as long as you cut the fender-liner properly).
Old Sep 26, 2008 | 04:37 AM
S2KILLA's Avatar
i agree...
but if u are going to go with the Bypass, i would just cut the intake about 8" above the filter and install the bypass there... the further away from the engine the better since it will draw less hot air...
Old Sep 26, 2008 | 04:47 AM
i my honda
Global Mod
Yes even a small amt of water can cause damage. It does not have to be a lake... But for the AEM bypass to work (open), IT DOES have to be a lake... You have to have enough resistance from the filer/pipe being filled with water for the baypass to open. So it has to be pretty much completely submerged in water. Go ahead and play with an intake with the bypass and a shop vac. You can pull in all kinds of water with the valve installed!
Old Sep 26, 2008 | 04:50 AM
HondaKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
Yes even a small amt of water can cause damage. It does not have to be a lake... But for the AEM bypass to work (open), IT DOES have to be a lake... You have to have enough resistance from the filer/pipe being filled with water for the baypass to open. So it has to be pretty much completely submerged in water. Go ahead and play with an intake with the bypass and a shop vac. You can pull in all kinds of water with the valve installed!</TD></TR></TABLE> I gotta try this!
ic89
Oct 24, 2006 12:11 AM
xxintegrlxx
Jun 22, 2005 03:38 PM
Fidelio25
Jul 7, 2004 03:54 PM
infamousALLMTR
Feb 16, 2003 11:07 AM
civic7gen
Jul 24, 2002 05:29 AM
