Problem
Old Sep 23, 2008 | 11:29 AM
stupidguy10's Avatar
Default Problem
So yesterday i was driving when suddenly my car started making this god awful noise...its a real bad knock....oil is slowly leaking out where my motor and tranny bolt together....did i throw a rod? any information would be much appreciated...thanks
Old Sep 23, 2008 | 12:19 PM
instructor74's Avatar
Default Re: Problem (stupidguy10)
when you say knock it makes me think of a spun rod bearing. it might be time for new engine. the oil leak between your engine and trans is more then likely your rear main oil seal. not an expesive part just a bitch to change out you have to pull the trans and clutch to get to it and if you have a knock in the motor not woth doing
Old Sep 23, 2008 | 02:00 PM
see the thing is my motor has less than 25000 on the rebuild and a new tranny clutch and axles were put it less than a month ago....i just find it odd
Old Sep 24, 2008 | 08:30 AM
anybody else have any ideas?
Old Sep 24, 2008 | 08:36 AM
94EG8's Avatar
Seagull Management
Default Re: (stupidguy10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stupidguy10 &raquo;</TD></TR><TR><TD CLASS="quote">see the thing is my motor has less than 25000 on the rebuild and a new tranny clutch and axles were put it less than a month ago....i just find it odd</TD></TR></TABLE>
Axles and clutch really don't enter into this at all. The rebuild does to some extent, but its still easily possible that you spun a rod bearing, the rod bolts might have been torqued properly, the assembler might have gotten assembly lube on the wrong side of the bearing, who knows. The rear seal really shouldn't have blown out this early though.
Old Sep 24, 2008 | 11:05 AM
im not saying that my axles or clutch have anything to do with it...just stating that i have poured way to much money into this car in the past month....although when i was trying to drive it home from work yesterday when i would let out the clutch it would vibrate so much it was hard to drive....and the clutch pedal wouldnt come fully out until i hit the gas....a few more things that might help out i guess
projectTeG
Transmission & Drivetrain
Sep 10, 2008 07:16 PM
DC2_ALL MOTA
Oct 21, 2006 09:43 AM
Dignan
Jan 31, 2006 05:25 PM
cbpldc
Jul 16, 2002 03:33 AM
hybridcrx
Mar 13, 2002 08:41 AM
