y7,8 and z6 crankshaft
Old Sep 23, 2008 | 10:54 AM
ryc555's Avatar
Default y7,8 and z6 crankshaft
I was wondering if the y7,8 and z6 crankshaft are all the same? thanks h-t!
Old Sep 23, 2008 | 11:01 AM
evildc2's Avatar
Default Re: y7,8 and z6 crankshaft (ryc555)
y7 and y8 are the same
not sure about z6
Old Sep 23, 2008 | 04:34 PM
ryc555's Avatar
Default Re: y7,8 and z6 crankshaft (evildc2)
thanks man. just pick up a crank from a z6, i need to do measurements to be sure.
Old Sep 23, 2008 | 05:19 PM
thumper64's Avatar
I believe I read that the two will work interchangably, but the Z6 has more oil journals.
Old Sep 23, 2008 | 05:34 PM
ryc555's Avatar
Default Re: (thumper64)
thanks man. so it won't work a z6 crank on a y8 block,rod etc?
D16 and D17 cranks share the same size main bearing diameters.
D16 and D17 rods all have the same major dimensions. The D15 rod is shorter (in general) and has a smaller bearing size, although the wrist pin bore is the same.
D15Z1 and D15B motors have a rod that is the same length as a D16. Other than the rod length, the rest of the bottom end is D15 spec (i.e. rod and crank bearings). D15B has D16 sized rod journals. D15B uses the same p28 rods that the D16z6 does. All other D15s have smaller rod journals.
i read this online.
Dmonster
May 28, 2010 10:36 PM
mattie_96
Oct 8, 2006 06:18 PM
d16dcoe45
Oct 4, 2006 01:03 PM
turbo sol
Oct 20, 2003 07:07 AM
